lowh07
Best I've seen yet
Preciate it. I don’t know if anyone remembers my post maybe a month ago about the blown out displays, but turns out it was fixable. Also, the missing dash lights I mentioned were due to a blown fuse (#49). I must’ve popped it when I was searching for a good power source for my nitrous
Got my cheap sunvisors today, had these ugly airbag warning stickers... i decided i couldn't live with.
Seamer and some minor burns and got them removed.
Maybe minor damage, still a little wet... :)
Better then the stickers!!
if those don't work out you can put on a set from a k2xx with the led's built in
Sparksalot
Bastrop County, Texas
Trying to replace my front shocks. Any ideas HTF to get this top piece to slide down so I can get a wrench on the end of the shock while holding the tip?
I’ve been using percussion but, not sure if I’m applying it in the correct spot.
all the videos iv studied just show complete struts coming out and going in, except one. In that video, all the stuff at the top just slid down.
E84E4ED2-9B5D-4699-95F5-649B32A6D5BB.jpeg 4E21865B-A64A-4D8D-AF56-B5AC728513E3.jpeg C2CACA48-5DF6-4E24-9D19-07E664DE66EC.jpeg
View attachment 269281 View attachment 269282 View attachment 269283
I haven't done one myself, this is for a bmw but should be approx the same procedure
cfmistry
Going to install this tomorrow but wanted to know what I can tap into in the side fuse panel so I can hard wire it. Any suggestions?
Do you want constant power or switched? Switched is easy, right at your rearview mirror.
JasonW4141
