Much better for sure. How’s it drive now?Forgot to post yesterday. Got an alignment after the ball joint and upper control arm + Bilstein 5100 install. Much better
Drives great! Love the 5100’s! Nice and crisp after the double -ball joint fix on the pass side!Much better for sure. How’s it drive now?
Whatchoo talkin’ bout Willis..?No "That's as close as we could get it" or "These things can only be brought close to spec" ?! You might need a second opinion and their equipment may be out of calibration.
Yes, I recall some of this myself. In fact, I’m pretty sure Tony ended up with the techs “losing” the sheet out the window and basically refusing to show the before / after printouts.Had a few threads over the past few months where people were being told all kinds of BS when they took their GM trucks/SUVs in for an alignment. Some were slightly understandable (if just giving them the benefit of the doubt) since the vehicles had mildly modified suspensions. Others were total BS from the tech not knowing what he was doing.
So what do you see wrong with this alignment?
Ah! Apologies, your facetiousness skimmed over my head. [emoji1787][emoji23]Yes! I popped a BS flag on that one.
I see nothing wrong! I was being sarcastic in that yours, having such good results, must be a fluke or they fudged the numbers or their equipment is out of calibration. You know- since these things can't really be aligned.
You forget who you’re talking to? Lol.Whatchoo talkin’ bout Willis..?
Ah! Apologies, your facetiousness skimmed over my head.![]()
Replacing my control arms made a big difference for sway (more of a YAW feeling) over bumps on the highway. I’ll probably replace the sway bar endlinks and bushings as well just to finish off the suspension refresh out back.Have you had a chance to drive it for a bit and see if it made a difference?
No pics!?!?Finally got the last c clip in after loosing one. New heater hoses, and put on shrouds for fan. Loaded coolant and oil. Forgot key was on. Hooked up battery and the fuel pump fired off. Damn I wanted to spin the baby over for awhile to see oil pressure. But the dang thing started YES!!!!! Shut it off real quick because it was fuc#$&+ loud. Pulled fuse for fuel pump. Will pull fuse for spark and spin the baby over. Started it twice real quick thinking I could burn the fuel off, but nope. One happy camper. Need to tow to welder for down tubes to y pipe and magnaflow cat back. Then custom tune. WOW what a day
Anybody ever PAID to have their headliner redone? Mine is dropping and coming apart at the edges some. What is a reasonable price? This is something I will pay for, not try and learn on the job! I don’t like the factory material, I’d rather have something more like what my newer cars have. Just looking estimates if anybody’s gone through this. Thanks.
I got a quote from a local upholstery shop for something like $200 if I pulled it and reinstalled it. I figure I’d do it myself when the time comes. Mine just has a couple stains.Interested as well, mine sags like grandma's tatas.
ive seen yt vids, you pull the headliner, rip the cloth off, then sand the foam off, you can now buy what ever fabric you like and put it on there with contact cement.
we had/have a place called the rag shop here, (who knows if they are still open these days) it was a sewing outlet type place, place like this sell everything and any thing you might like.
Sounds pretty reasonable.. wait. To remove / install yourself..? Damn. Wonder what they’d charge for the whole job. I’d much rather pay someone to do the whole job. Not sure how I’d be transporting this bigass thing while removed. Lol.I got a quote from a local upholstery shop for something like $200 if I pulled it and reinstalled it. I figure I’d do it myself when the time comes. Mine just has a couple stains.
I would have everything pulled out except the last couple things holding it up, then finish the removal at the shop. 95% of the work is removing all the trim pieces.Sounds pretty reasonable.. wait. To remove / install yourself..? Damn. Wonder what they’d charge for the whole job. I’d much rather pay someone to do the whole job. Not sure how I’d be transporting this bigass thing while removed. Lol.
