Tonyrodz's Tahoe Build Thread
Sam Harris
***** fought me but I won in the end!
To add powerfold you need both door switches--driver's master switch and passenger window switch for everything to work.View attachment 268352 View attachment 268353
Each has a different part number. Also--They have nothing to do with the bcm, so no bcm programming needed.
Funny--both master switches have different part numbers but they both function exactly alike.
Yes!! Glad you got them working Tony! I had no idea the switches on both sides would need replacement. So they are paired with the mirrors..? Crazy!! Now, about your hyper flash.....
Yup, everything came from the same truck. As for the hyperflash--I have resistors on everything, no idea which one is doing it--BUT--All the cool kids lights hyperflash lol!
wjburken
Eastern Iowa
Check that out sauerkraut! Now you can go all Top Gun and fold them in at high speeds like the wings on the F-14!
Your Tech2 can tell you which light is causing hyper flash- it will show as a light out in the test menu.
Scottydoggs
NJ
happy they worked. i use mine every time i park.
should one get moved in manually, you'll need to hit the open and close 3 times to reset the motor, it will click a few times.
lumbar in mine is set down all the way, the side wings as wide open as they can go. im to big for all that. same for the ss.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
DAMN!!! Funny that you mention that--neither of my fobs work now. I thought it was the battery. So what's RKE, and how do I get my fobs to work again? Can I reuse the RKE from the old switch?
Just reprogram keys again
RKE is remote keyless entry and I think the module in the passenger switch needs flashed to the BCM with your tech2
wjburken
Eastern Iowa
Candielaine
