Aftermarket wheels
Dan H
That looks good do you know what the offset is on your Vossen wheels and what size tires are you running? Any rubbing issues?
Glefevre87
I’ll have to check on offset as I’m not sure. Running stock tires for the time being and I have not had any rubbing issues. Love the look. Get chrome deleted next week.
YukonDough
Where are you getting chrome delete? Paint or wrap?
Swatdoc
I just bought a set of the replica ‘19 Sierra Denali wheels in gloss black. I got them in 20” x 9”, as I’m going to run General Grabber A/T tires. Better tire selection in 20”, and the taller sidewall should ride a tad smoother.
I did a test fit today to check caliper clearance, and it’s all good - approx 1/2” clearance between the back or the spokes and the calipers. Getting everything installed tomorrow- will post up some pics
Glefevre87
It will be done at American wheel and Tire in Houston. It will all be painted. Had a delay as I have been traveling and they need the vehicle for 6 days. Hoping to have it completed now in the next month or so.
Swatdoc
Tires and wheels are on and everything fits great. Went with 285/55R20 General Grabber AT tires. within 1/4" of the stock tire diameter.
AZCreeker
Anyone know if we can fit smaller wheels (18s maybe) on these? I personally like the look of more rubber/less rim. Plus, it opens up a lot more aftermarket options.
you can run any 6 lugs chevy wheels on these.
from OEM 18 of the current gen to any Previous gen or after market.
the choices are endless
Some even run 17"
Swatdoc
Our Yukon isn't lowered - stock air ride suspension for now. It automatically lowers 2" when you turn it off, that's why it looks lowered in the pics. I'd actually like to level it - preferably raise it a tad in the front. Just not sure how to do that with the AR suspension.
the wheels are replicas of Sierra Denali wheels in gloss black. Got them from Replica Wheels on Ebay. Tires I just got from Discount Tire.
The TPMS were an issue - couldn't get aftermarket ones to work at Discount Tire, so we had to pull the stock ones and use those
TwoFeet020
I live in Miami, FL and purchased my rims and tires already mounted with TPMS sensors shipped from California. Upon installing on the truck, the tire pressure sensors dont read. I found this odd being that they programmed the new sensors on the new rims.
Long story short, i called the rim shop who used Bartec programmable sensors programmed at 315mHz. This is the incorrect frequency. Should be 433mHz. I called Bartech tech support and they told me GM had given the aftermarket wrong info on the frequency and there should have a new program update in about 3-4 weeks to correct this.
Part that sucks is that I have to drive without a reading until this comes out and find a local shop with a Bartec reader to reprogram for me.
Trides
Alberta
Read post #2
https://www.tahoeyukonforum.com/threads/leveling-a-21-with-air-ride-suspension.123793/
TwoFeet020
Can anyone chime in if speedometer recalibration when using 24” rims/tires is recommended?
tabraha
S.C.
Would depend on the % of overall diameter change with your particular tire. Throw Waze up on the screen and see how it compares at 70 or 80 on the interstate and then decide.
tabraha
S.C.
Posted a bunch more pics in my vehicle specific thread but I put on Fuel Rebel 18x9 +1 offset rims with 275/70R18 Ridge Grapplers this weekend. Really makes the AT4 package look substantial.
So for those who were curious 18's will clear the calipers easily. Just to my eyeball you may be able to go 17 but 18's are perfect for a nice balanced offroad tire combo with plenty of sidewall room to air down when desired.
TwoFeet020
lol exactly what I did. Waze is showing 2mph less than the speedometer
I am running 295/35/24 tires
1948Buickroadie
