Tonyrodz's Tahoe Build Thread
What is a Fleece module?
It allows all your lights to remain on when you put your highs on.
I see. Thought you had that fixed. Sorry.
Np. I have too much $hit going on with this "Princess" lol. Kind of hard to keep track what's going on.
While replacing the srs sensor I had to remove that plastic skid plate--all the bolts were finger tight, and somehow 1 bolt hole was stripped out. I can't even imagine what else I'm gonna find.
Don’t suppose you could maybe solder it back on?
I don't think it would be possible. I ordered an Acdelco plug. Won't get here til Monday. Curious tho--since it doesn't throw a code I wonder if it goes into closed loop. Weird--I disconnected the battery for the srs sensor, and when I reconnected I got a reduced engine power along with the pedal sensor and another code I forgot. I haven't had a reduced engine power code in over 4 years--strange. Everything reset fine tho.
Sam Harris
Both just for charging only. What's a "buck" module? I don't have it through my DD.
It drops the voltage from 12, to 5v. I’d highly recommend it..! So if they’re both for charging, you’d need 2 of them, unless you have devices that want 12v for charging..?
Hmmm, I just planned on plugging my radar or using it to charge phones in. Do I need to worry now? Will it blow the battery up or something?
Conedaddy
