STP "direct injection" system cleaner
Prospect62
Central NY
Has anyone tried this stuff?
Direct Injection Fuel Injector Cleaner | STP.com
First time I've seen a product like this aimed directly at us GDI owners. I'm kind of curious how it works without being aspirated into the intake somehow. If you just put it in the tank how the hell does it reach the valves and such?
I don't normally buy this crap but I'm trying to do whatever I can to avoid GDI issues. I have a catch can installed that fills up every 1500 miles or so (I do a lot of short trips in cold weather). Figured I'd see if anyone has used this. I had very good luck with Chevron Techron stuff in my 08 Crown Vic so I'm not a total skeptic.
Thrust
ICT
It doesn't reach the valves, it's just made to clean the injectors. Not sure it's any better than the Techron, or Berrymans, or Seafoam, etc.
I just buy the .99 cent crap at walmart and throw it in all my vehicles at least every couple months, as to if it does anything or not, who knows but no sense in paying $5.00 when the .99 cent crap has the same ingredients (read the labels).
tsuintx
DFW
Yup. Not going to help a lot with valves, really, since the DI system sprays the fuel directly into the cylinder. I used this on my truck when I bought it back in August and have another bottle to use on the Suburban when ever I get around to it...
https://www.amazon.com/CRC-05319-Intake-Valve-Cleaner/dp/B00PHNQKR2
When I used it on the truck, I did get some black smoke and stuff and I guess it runs a bit better/smoother. Not that it had any running issues to begin with, really. It's not the end-all, of course, but I'll keep on shooting a can of that stuff into the intake every now and then, just in case. As well as Techron in the tank a couple of times a year.
STORMIN08
for valves...the GM TOP ENGINE clean would be my choice, or better yet...JUST WATER.
i have used this on several older vehicles with slight ticks and cleans up the carbon very well...not sure who well the cats will like it, but to date even on newer cars i have not had any issues that i can speak of.
Prospect62
Prospect62
Central NY
I saw this CRC stuff while researching the original stuff I posted. Looks like the CRC would be way more effective and I'm going to try it. Probably won't hurt.
sealandsky
Minneapolis, MN
I'm using the CRC product on a 10K miles recurring basis as well as the throttle body cleaner.
petethepug
Michael
SoCal
Ha! Studabaker Tested Products, a member of the Clorox Companies.
RobDenali
Indiana
I always used seafoam but I was convinced to try Berrymans and I will never go back to anything else . So easy and the PEA really cleans all the carbon out
lol I was just reading this again I think with the way I drive I "clean the carbon out" on a daily basis, even when I go to clean the throttle body there is hardly anything there to clean.
Tiredmechanic23
This, cleaned my TB the first time at 100k and had just the littlest bit of anything to clean out of it.
1948Buickroadie
