Randeez 2012 Budget Yukon Denali Build (stick on hood scoops galore)
randeez
randeez
south florida
Will find out how slick I be. Made up hose to go to future chiller, but it should also work to loop the system for now so I can check for leaks and flow of this pump n stuff
Removed the air to air intercooler, recounted the tru cool 40k in its natural habitat, need to replumb tomorrow
dude wiff'd on the bung for the water pump also... i couldnt find a 16an to 16an oring union so i just threw an oring on an oring to an fitting which would work fine except it threads into a stopping point, which i clocked and marked for him but some one messed up. so will grab a female/female 16an union or something- will space the pump out a little further from the tank but thats no big deal
20201231_213406.jpg 20201231_213435.jpg 20201231_213750.jpg 20201231_213753.jpg 20201231_213920.jpg
randeez
randeez
south florida
put some water in it last night, going to leak without the oring fittings completely tight, prob wont be able to order or pickup a 16an to 16an union till next week so not gonna be doing much.
going to bend up some tubing for the tranny cooler since it will hopefully not move for a while.
need to add a relay for the intercooler pump and wire in the new temp sensor.
and big fuel pump is just constantly on for whatever reason so i need to trouble shoot that also, thinking the hobbs switch is shot out or trigger wire is touching ground somewhere
JRSB16
