Kbuskill's 2008 Burb LTZ "MOD" Thread
Fosscore
I see the evil twin is still pulling strong into the latter 200k's...nice!!
Good maintenance list going there and still loving those wheels in the sig. Good father/son work too. :thumbsup:
kbuskill
kbuskill
NE. FL.
Thank you sir. It is good training for my son and good for me since I am not as able-bodied as I once was.
pwtr02ss
Tennessee
You talked me into it... sent the fresh oil off today to get the VOA done on it.
I will be sure and post the results in case anyone is interested in using the Delvac Extreme 15w40.
Also got all 3 power steering hoses replaced today. Getting the new hoses to seal into the steering rack was a royal pain. No more leaking hose.
Do you have the part numbers handy for the 3 hoses? I'm only seeing the pressure and return from cooler. I'm thinking there should be another. I also need the transmission lines. I don't have the heavy duty cooler so I'm getting mixed numbers for that as well, if anyone has those...
kbuskill
kbuskill
NE. FL.
GATES 352182 pressure hose
GATES 352183 return hose to cooler
GATES 352281 cooler to reservoir
The last one from the cooler to reservoir is ridiculously priced in my opinion. $37 for 36" of 3/8" hose with some split wire loom around it.
I purchased 36" of 3/8" transmission hose from Amazon for $10 and reused the wire loom off one of the old hoses.
You only need about 20" of hose for that line.
pwtr02ss
Tennessee
Thank you sir. The Gates appear the same as OEM?
kbuskill
kbuskill
NE. FL.
Latest Blackstone Labs UOA report...
This last oil change I switched up to Mobil Delvac Extreme 15w40. Interested to see how the next report turns out.
Strange lead readings, indeed. The dual filter, cooler, etc. was done at 238,104 miles? What air filter are you running?
kbuskill
kbuskill
NE. FL.
No the dual filter setup and aftermarket oil cooler were added shortly before I started taking oil samples for UOA.
I am all but positive that the cheap Chicom oil cooler is what is leaching lead into the system. It is the only thing that makes sense to me for the lead readings to peak the way it did and then decline. And the copper numbers are good.
I have a K&N filter in there currently and it is probably over due for a cleaning. I will make sure and clean it when the new radiator goes in.
kbuskill
kbuskill
NE. FL.
I am curious to see what the VOA has to say about the Delvac Extreme. That will determine for me when I take my next sample and how long I feel comfortable running this oil on the first oil change.
a1parrothead
