LED replacement tail lights
Looks like it's time to order a resistor. A previous post said only one was required if I read it correctly.
Just ordered mine off of Ebay. They should be here in a couple of days. Those of you that have added these to take care of the cruise issue, can you show how you hooked these into the brake wiring please?
Thanks.
Thank you Tony! I greatly appreciate greatly as I'm sure others do as well. Unfortunately, wiring isn't my strongest suit.
This one is pretty easy. Almost impossible to mess up.
Just make sure you secure the resistor on something that won't melt. They do get hot.
St. Louis
Do those sealed, black box resistor packs that come with some of the aftermarket LED tail lights get hot also? Because I always just use the 3m tape that's on them to stick them to the back of the light housing. This is on my GMT900, but same principle I'm guessing?
I'm not really sure. I've never had a set myself, just the bulbs themselves.
F
Flingflanger
OP here. I just wanted to say, yea you have to add the extra resistors. I actually bought and installed the recommended control module as well. And imo that was unnecessary since it works just fine with the resistors. They were like $8 on ebay.
Also I only had to add 1 resistor, not one on each side in case anyone was wondering. And I just used T-taps instead of fancy soldering. :D
adventurenali92
Big Bear Lake, ca
I was a dodo head and didn’t realize that the resistors added on the tails were only on the turn signals, until I looked at the photo you posted of your tails.... lol. I was like “oh maybe I should check mine to see if my resistors are in the same place....” :doh2:
Bill Barnes
Catlett, VA
Usually the sun . See the roof and hood paint fading and chipping almost every time in south states, tx, socal, fl, ...
I’m sure a regular wax would help tremendously, but you’d have to be the original owner from 02 lol
Agreed, the sun causes the damage to the clearcoat. My 2005 Yukon XL has been garage kept since day 1. The paint looks like it did day 1.
JamesinAbilene
