LED Tail lights
03GMCYukonXL
Does anyone have any recommendations for LED tail light that ACTUALLY are error proof and have a built in resistor? I ordered some and had the rapid flash, learned about the resistor fix, then learned that there are LEDs with a built in resistor. I ordered form Amazon what they SAID was an LED with a built in resistor, but I still have the rapid flash. So either I'm missing something or they lied.
LsHart
Senior Member
Go to Carid.com. input ur truck info and look at ur options. I replaced mine with LEDs and direct plug in. No rapid flash. And if u can stop the rapid flash, replace the turn relay with a LED relay.
CrankCalls
SE NC, USA
Replying to this so I can update shortly. I have a set of Oksiwa LED that are coming in the mail today. Supposedly have resistors but i have the LED relay on standby.
the auxito bulbs (genuine auxito) not the fakes will not hyperflash if you order the non-hyperflash type bulbs from them. They typically sell both types.
this is a link to there ebay storefront
Capybarbro
