Intermittent Electrical Issue
PJDYukonXL
Orlando, FL
I drove my 16 Yukon XL 5.3 two nights ago and noticed it starting sluggishly. I had a number of errands to run and it seemed to get worse every time. I left the vehicle running as I went in the store on my last errand in fear the vehicle wouldn't start again. In the way home I stopped at the auto parts store where they tested the battery and it was good.
Truck started right up afterwards, no problem. I drove home and forgot about the issue. Last night I go to start the truck and it just clicks like the battery is completely dead. I try a couple of times and nothing. Left it over night to deal with today.
This morning it starts up, sluggishly again and then says its set to memory 2 and all my presets on the radio are gone.
I've checked the terminal connections and they all seem to be good. I'm wondering if it's a bad cable/ground?
Does anyone have an image or file showing all the ground connections/locations to check?
If anyone has other ideas, let me know! Thank you in advance!
Big Mama
Virginia
Welcome to the forum from Virginia. Does sound like a ground issue but electrical problems can come from lots of places. Do you know if they load tested the battery? If you have a multimeter check battery voltage before starting and after.
PJDYukonXL
PJDYukonXL
Orlando, FL
Before: 12.8
Running: 15.2 initially then down to 14.5 and held around 14.7
Big Mama
Virginia
Sounds like the battery and alternator are working well, which leaves the ground cables, battery cables, and the starter though it would be rare for one to go bad that soon.
91RS
GA
The battery cables are absolute garbage on these. The negative and the short positive cable on top of the battery. I would go ahead and replace them even with the new battery.
DenaliBQ
the ac delco batteries are known for dead cells on the 16s and other trucks
Big Mama
Virginia
Update: Took it to another shop that specializes in electrical systems... they load tested the battery and determined there was a bad cell. Replaced battery and all is good now!
that’s great. Thanks for closing the loop for the next guy
Jason in DLH
Cheeseburger and Fries
MN
True this. My radio and lights were acting strangely for the longest time and simply couldn’t figure out why. Problem seems to have been fixed after I replaced my cracked and corroded front impact sensors as it’s going on a few weeks without issues.
Ben2019LS
My 2019 Tahoe just started doing the same thing. Sat for a week or 2 due to Covid and I had the doors open a bit while doing the window trim blackout. Thought it was just the doors being open a lot and not being driven. I drove it 5 miles to Publix turned it off and then it was dead. A friend came by and jumped me and I went to Auto Zone where they said the battery was fine. Parked it at home and it has been hard to start or barely starts each time. Gauge reads 14-15 while running. Maybe I need to have the battery checked again?
Big Mama
Virginia
You may want to take her for a good long spin to see if that charges it back up. If not get it load tested.
PG01
Up here to the right
Newer cars and trucks depend so much on a fully charged battery that can handle the electronics, computers, etc... with the key off...a battery that is weak or has a bad cell will wreak havoc on the vehicle.
Get a new battery and make sure it’s fully charged before installing, ive had batteries go bad in 1 year or last for 7 years.... luck of the draw imo.
Ben2019LS
Thanks for the info guys, I ended up getting an AGM battery from Advanced Thursday after driving there and it not starting and testing bad. Worked Saturday and was busy Sunday but she fired up no problems this morning. See how it goes with some more driving the next few days.
Charlie21ny
