Tonyrodz's Tahoe Build Thread
Man, you need a tuner to look at this. I forgot, which do you have? find your AutoCal yet Tony....?
It was originally tuned by the place who did the 1st motor originally, back in 2017. That's why I went with the exact same cam with this motor. I still haven't found that damn Autocal. I think it fell into that bottomless pit where everything goes that you can't find :mad::mad::mad:
at idle a cam will run rich, drive around and see where the ltft go at cruise speed.
I def will get that in a few days. Thx @Scottydoggs.
The popping could just be your catless exhaust setup. The LTFT are definitely off alot, but at idle isn't the issue we need to see that on some WOT! So go ahead grow a third arm so you can steer, hold the scanner, and take pics.
I'll get it as soon as I can. I've never heard that popping before.
Scottydoggs
NJ
the ltft are far from anything worth looking at wot. they actually lock in at what they were just before entering PE mode. it then runs off the PE "power enrichment" afr.
tony, if you can scan commanded air flow on the scanner there idle and cruise should show 14.7, wot will likely drop to 12's. thats what pcm is commanding, but whats actually coming out the tail pipe read by a wideband could be way off, or dead on to whats commanded due to it being maf tuned already.
this is why you need a wideband to know what the true AFR is when wot tuning.
I think I can record Luve Data with the scanner I have. Would that help? Would I need to record while driving it? Or would idle be fine? Thx for any help Scotty.
Bear77
South FL
I believe we all think you should get in there and find that autocal!! And you should do the recording while driving is what the consensus seems to be. Guessing idling doesn’t give the info needed. Just from what I’ve read...
I've tried to find that damn Autocal--no luck so far :mad::(
Sam Harris
Definitely need driving data. Though I’m not sure how much WOT you should be doing with the issues you’re having, I think that will be the most beneficial.
nortonte
