R3cord303
Posse In Effect
Oregon Valley
Here’s all thats left of the bearings on that side
Ont240
Ontario
Had an intermittent stabilitrac message and ABS light for quite some time,until it finally was always there. No drive issues. A friend has HP Tuner program so we hooked up and gathered the stock Programming and ERROR code. C0045, left rear wheel speed sensor.
Ordered an AC Delco unit from Rockauto and installed.
Fixed. No light or error messages
alpha_omega
Michigan
Might be worth checking your grounds and the purple wire running to your gas pedal. A few years ago I had the same issue and it went into limp mode every so often. Showed up as wheel speed sensor but turns out that wasn’t the issue. One of the grounds in the back needed cleaning, the passenger side pillar ground was “meh...ok”, but I cleaned it anyways and adjusted the harness hack job running to the pedal. Been right as rain ever since.
Derick
Indy Suburbs
I gotta say, having the new cushion and cover on the drivers seat.....woah momma. I can actually drive it without the whole left side of my body hurting because it was so broke down. Drove it to cincy and back, and super comfortable. Now if I can get rid of the intermittent paint shaker vibration, that'd be greeeeeat.
How much was the cushion and cover? is yours heated/cooled? I need to do the same at some point
Derick
Indy Suburbs
95/ea including shipping on email. We'll see how they hold up.
https://www.ebay.com/itm/2007-2008-...om-Leather-Seat-Cover-Light-Gray/332352875522
https://www.ebay.com/itm/2007-to-20...cement-High-Density-Foam-Cushion/332907624321
Paid a hundo to have em installed. Watched stuff on how to do it, didn't want to do it. I just removed the entire seat and dropped it off at their shop, two days later and she was done.
@915_Tahoe Can you tell me the drivers side seat heater part number is
looks like there is different parts, one for the seat bottom and one for the seat back
mine has heated and cooled seats
2012 yukon xl denali heated & cooled vin: CR189350
thanks, I am pretty sure I finally found the right parts and ordered them came out to about $300 total, looks like these are starting to become scarce, for whatever reason the 07-11 looks the same but is a different part number and cost about $30 more. i might need the heater pad also mine has never really work all that well, the 18 silverado will about roast my ass
mikeyss
Longmont, Colorado.
If you have cooled seats, you have a TED that also heats your seats. You do NOT have heating pads that the non cooled seats have. You have what looks like this:
Escalade2007
