mattbta
Frisco, TX
8.5 years ago, I replaced the driver blend door actuator and never put the kick cover back on. The screws have been in a baggie in the console. Last week, I replaced the passenger side which required taking the dash cover, a-pillars, air bag, vents, and some supports off. I broke a mounting clip/tab support.
Today, the repair of my dash cover tabs fully cured, so I reinstalled it. Decided to put the kick cover back on. I now remember why I never did. That screw inward, right behind the center console is impossible! I taped it to my 7mm socket and got it started. Decided to yank the socket out and attach to the ratchet. Couldn't get it turned much because I couldn't get the socket back on it.
Started taking parts of the center console apart to see if I could get at it and realized there were some screws that would also be impossible to remove. Put what I took off back on.
Figured it was well enough and gave up. Might wrestle with it some more later. Just ran out of fecks to give.
latvius
Ariton Alabama
I dont put that screw back, never been a issue the other two screws hold it good enough.
Sam Harris
Washed it yesterday, had to get the nasty crap
From the little snow we had off. Today, did some detailing. Really liking the way the wax works on the rear window trim. Thanks @05Single! Boring same Ol pics.
Looks good Sam. Man what I would do to have a garage that big....
Sam Harris
That DOES look good, @Sam Harris !
Thanks guys! I think the wax does the trick on the trim pieces very well. And yes Mark, as soon as I opened up the garage door when we were looking at the house, I was like: “ah hell yeah!!”.. [emoji23][emoji631][emoji106]
Sam Harris
I have a 2-car garage but, with two cars, that's about all that fits. They don't make 'em like they used to!
That’s for sure! Garages used to be “generously sized”! Now you’re lucky to fit 2 sedans in a garage! Forget about a truck! Used to fit 2 (bigass) cars, and still have plenty of room for a small shop, as well as fridge / freezer.
But aren’t you working on your garage? Lol
Well I have to make my garage a drive-through, and then build a small shop in my back yard, and then I’ll be ok. But yes, I’m working on the old one car 1950’s garage right now. I feel like I’m building a tiny house though....gotta make good use of every bit of space especially since I’ll be basically losing the back wall as it will be an overhead door.
I hear ya. I'd better quit complaining, I've got it good, relatively speaking. I can always park one outside when I need the room, but I don't like to. The Hoe sat out all summer while I worked on the deck wood, and she's lovin' the shelter of the garage.
Sam Harris
And I finally decided to replace the standard NNBS shifter with the new one that @Adverturedenali92 suggested (maple or amber or something..?) Thanks Chase!! - anyway, color is pretty good. Not exact, but a lot nicer than black. And I bent the shifter arm enough so it’s closer to stock. Much better!
Now, I’ll have to do it all over again, when my replacement shifter boot arrives Wednesday.. [emoji3525]
I left the original in for now because mine’s pretty trashed and suspect it would have ended up in two pieces anyway, had I put it on the new shifter...
Before, with the stock NNBS shifter:
In park:
In drive:
After I bent the arm in the vice, I needed to clean up the shaft a bit since it was a little torn up / rough from the vice jaws:
Now the new park position:
And drive:
Hard to show, but a significant difference after bending the arm, compared with the other NNBS shifter:
Then I started pulling off the shrink tubing I did last time, and desoldered the wires. These are really short, so didn’t want to cut any off if I didn’t have to:
Soldered to the original plug:
And 3 layers of shrink tubing, because I love that shit.. :
Factory plastic keepers hold the wire in perfect:
New park position:
Tow / Haul (BBP “Sport” mode) activates just fine, and the drive position:
In park:
In drive:
And drive:
New park position:
So much nicer. So you bent the shifter up so it sits higher? I need a vise. I bet if I tried to bend it while it's attached I'd def break something.
Phlipnstik
