I have a window that used to come all the way through the interior so I pulled the sash, replaced it with plywood, and sawzalled off the interior so it can be rocked over. The outside is an area that you really can’t see unless you go over there but I might side over it later if it bothers me. I added 6 outlet boxes in the ceiling that turn on with the light switch and am going all LED lights. I bought (2) 8’ strip lights @14,000 lumens each and just order 2 more, plus I have a ufo one that’s about 30,000 lumens. It’s gonna be bright af and use way less power than my old fluorescents. I’m putting plugs on each light do they can be moved around for the best locations as well as replacement if needed. If they were hard wired it would be a hassle. I also splurged on one nice cabinet on wheels that can sit in front of the rear overhead door that I’ll install. It needs to be able to roll out of the way. I’ll build a new workbench with the top made out of 1 1/8” floor sheathing plywood, so it will be sturdy af. I’ll add a cabinet underneath with sliding doors. It’s a work in progress but here’s this mornings shot of the bright first half with my new cabinet.
54FFDC26-99E7-4B53-A131-9EA41E5773AC.jpeg 149B1946-72EF-4B3E-A6B4-4DC093AEC7CD.jpeg 4344D240-883C-4934-81B0-67C2DEB58B6E.jpeg image.jpg
Some old school lumber I uncovered. Some actual 2X that is a full 2” thick and part of the original bench is 2 x 12 vertical grain Douglas fir that’s so high quality that it’s still perfectly straight, as if it’s made out of steel it’s so perfect.
8733B6DB-9157-4CD4-948E-2E458604B3F8.jpeg 551CF453-52E4-4FA4-851F-170694DBF57A.jpeg
Sam Harris
Back in my overhead door days, I installed 20x8s on three walls of a garage. It was a huge house at the top of a hill in the center of a few hundred acres. You could open all the doors and have a huge covered patio with a nice breeze blowing through. I'd like to have a setup like that some day, but just with two opposing doors cuz I actually use my garage. This rich dude with the three doors just parked in his and had a gigantic shop down the hill for his toys.
Well I was gonna just do a first skim coat to cover the screws and seams like the normal garage half- finished look but that kinda bothered me so I’m doing a second coat, sanding and priming in white. Looks so much better. Today I found an old oil tank dipstick and I mean old. Look at the phone number for Sunset Fuel- CHerry 6-3381 instead of 246-3481 and no area code. That was back in the days of operators so if you needed to call out of your area you dialed 0 and get the operator to help.
5FD9D4D3-B163-4DDF-8743-6EA8C4865278.jpeg A8F895B4-6AFF-47AA-A412-D11ADB022027.jpeg image.jpg image.jpg
Dantheman1540
Sugar Loaf Mountain
View attachment 262392 View attachment 262393
Doug fur is nice stuff I wish it was more common down here. Kinda funny lumber isn't true to size anymore, there was actually a couple lawsuits about it a few years back. The couple got home and found out they were deceived and their wood was smaller than they wanted. :manos::jester:
https://www.reuters.com/article/us-...ers-of-4x4-lumber-is-deep-sixed-idUSKCN1GO2TN
You can’t fix stupid. It actually does (or at least did years ago, not sure now) start out at 2” x 4” and then gets planed to 1 5/8” x 3 5/8”. The old stuff was always rough sawn.
I also stripped the ceiling. It had some weird fiber board shit and then for attic access it had this other weird contraption built, covered in the same oak stuff that the walls had. I pulled it down and found a bunch of junk up there. I’m gonna frame in an opening for wide pull-down attic stairs. The dude that used to own this house was a strange one. That cube hanging from the ceiling made no sense at all.
This wall came out pretty decent for 2 coats of mud and just primer. There will be no lack of outlets over my workbench, and I added a switched outlet for under cabinet lighting that I’ll install after I build a cabinet over the bench. I have 2 more 8’ led lights coming today and I’ll get rid of the final fluorescent. Amazon delivered the first pair of them a few days after they were scheduled so they let me request a refund. So that set cost me nothing instead of the $140 they listed for.
D52557F2-EDAA-48AC-AEBD-7D53BB6C0C75.jpeg EDB32C61-9B18-4BDD-B542-13598C7EB76B.jpeg
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
View attachment 262720 View attachment 262721
Looks real good man I can't stand that drywall and plastering ********.
Sam Harris
Awesome!! Yeah, my bigass garage had a whole ONE outlet when I moved in... thankfully, the sub-panel from when the basement was finished is right on the front wall of the garage, and had plenty of free spots, and plenty of cable capacity.. I added 3 -20amp circuits out there, and can still put in 220 whenever I get something that needs it, as I already have the second leg to the panel. Same with my shed wiring I installed last year.
I think I put 10 or 11 outlets in the garage and the shed is just ridiculous. I think there are 7, plus an exterior one, in 120sq ft. [emoji23][emoji1787] but I do use the shed as a half a shop all the time.
And I’m with 89Suburban... I hate texturing. The drywall and taping isn’t so bad but the texture. Bah..! I did get pretty good at orangepeel texture at my old house, but this one is knockdown and I just cannot get it right.
That’s just smooth wall. I textured most of my interior when I remodeled it years ago, including knockdown on a few ceilings. If I was texturing the garage it would look perfect. Smooth shows everything, and all I have on this is the texture from the roller.
Sam Harris
Ya done good Mark!! Yeah, I haven’t done a whole lot of drywall. I can tell you it would look like a steaming pile though, next to your work. (As with several things..) [emoji23]
varminpoolteam
