Wheel compatibility between 2021 and previous generation?
Dogged
I'm hoping to pick up my Denali on order in a few weeks (after being in the system for almost 4 months!). I'm not a fan of chrome wheels and it comes with the 22" wheels. I'd like to have a replacement set ready for when it comes in with possibly 20" wheels and larger tires (305s?). Does anyone know yet if the older wheels work on the 2021 so I can assume backspacing etc will be ok with current tire dealer recommendations?
I have an 2018 with 22s and 305 Ridge Grapplers that looks nice. I'd like to replicate this on the new one with some gunmetal wheels.
Bonus question of if anyone has put larger tires on and at what point does it need to be leveled to accommodate that particular size.
Thanks
DWSmoot
Charleston, SC
285/50r22 on 22” +24 offset. No level. Had one ready to install but did not need it.
Dogged
Dogged
Looks nice. The 285s are a little bit bigger than the 275/50s that are stock on the Denali. I'd love to put 305s without any mods like my 2018 if anyone has gone bigger yet.
Dogged
Dogged
I tried mounting up my wife's wheels today just for a test. As Tricky1 noted the calipers on the '21 are much thicker and will hit the 2018's wheel. It probably would need at least 1/2"-3/4" of a spacer to use those wheels. Her 305s probably would have cleared or at least with the heat gun mod on the wheel liner trick. They do not hit any suspension hard parts like the 2018's sway bar.
The 305s did not stick out of the wheel well much more than stock and would probably be ok. They look soooo much better than the stock tires.
I'm still on the fence of whether I like the stock wheels or not, so I may wait to pull any trigger. I hate just basically throwing brand new tires away. Hopefully some others will post up more options as time goes on and we can learn what will work or not.
DWSmoot
Charleston, SC
Does this have 2” level in the front? Looks high?... or is it just up in the jack?
Dogged
Dogged
It's still on the jack in the photo. The wheel was touching the caliper and I didn't want to tighten the lugs and scratch the zinc plating.
Paul Frandsen
Looks fantastic! I just added 285/50r22 Grapplers to my 2021 Suburban. I am waiting on black trim and rails for the build to be complete, but I am wondering what the ride quality has been for you and what tire pressure you are running? The ride quality has definitely been worse than the stock Alenzas. I've wondered if that will improve as the sidewalls soften? I have been running 36 PSI as rest and they hit 43 hot when at 90mph on the freeway. The tires cause the vehicle to float and bounce over bumps in the freeway and the car dives into the corners.
Thanks! I do absolutely love the look of the these tires. I have stock mudguards and when I back up with the wheels turned completely, I do rub slightly on the plastic...
Thanks!
Paul
Dogged
Dogged
Thanks!
Paul
Do your mudguards make the available wheel space smaller than just the mudguard? It would appear so by the photos.
BTW, my Ridge Grapplers on my '18 ride great. If firmness is your issue, then drop it to 34 and try it. Unfortunately, sidewalls on tires don't change their characteristics over time, so air pressure is your main control. I think they do make different load ratings in them. It's possible you got the max load rating. You might be able to swap them out since they are so new. Best of luck and the truck looks great.
DWSmoot
Charleston, SC
Thanks!
Paul
Looks good! No doubt the ride is a bit rougher than the Alenzas, but I am used to it. Have run these tiers on my last 2 vehicles. Its to be expected with a more aggressive tire and the 22's. I run mine at 40psi and have gotten over 60K miles on last 2 sets. I have not ever had any issues with mine floating or bouncing, that seems odd to me.
I think I am going to add a 1" front level to mine to get of the rake.
olyelr
Elk Rapids, MI
The 285/50/22 ridge grappler is a load range e tire, where as the 285/45 or 305/45 are load range xl. The xl’s will ride better, but do have much less tread depth. Also, the xl tires weight quite a bit less than the load range e tires (like 15 ish pounds, which is a huge difference).
Also, Dogged, the 285/50’s are a bigger/taller tire than the 305’s, so I would assume if they are running the 285’s then you will probably be good with the 305’s.
DWSmoot
Charleston, SC
Agree with olyler. The 285/50 is a taller tire and deeper lugs. What I will say is the Nitto Ridge Grappler is actually more like a 12" wide tire once mounted vs. some other 285's.
Swatdoc
I was looking at some Replica Wheels in the 22x9 size. It lists them as a 28 offset. Does anyone know for sure if these will clear the calipers. I do NOT want to have to run spacers
Thanks
Dogged
Dogged
I have successfully mounted Nitto RG 305 45 22s with no issues and they look and ride great.
91RS
GA
Most of the old body style wheels won't work on the 21+ because of the brake calipers. I don't know which ones will and won't though.
Conedaddy
