The ones that came with my Powerstop kit had no issues like that. I used a poor man's press (socket) and tapped them in that way. Then you got to watch when you grease the pin and slide it in it wants to balloon open. I use a pick tool to hold it open and let the air escape as I slide the pin in.
I tried a couple different methods including using a socket just the right diameter and it still tore, after I went thru 2 kits I said screw it and just bought a caliper wasn't going to keep wasting my money. maybe the hole where it fit's into should be honed out a little I don't know that might do the trick.
1BADI5
DMV
Well I got the Esky L94 flex fuel injectors today.......they look a smidge shorter, but I had to use some washers on the fuel rail with my FAST LSX 102 intake.
Otherwise based on the dimensions, the should fit perfectly once I remove those fuel rail spacers.
I'll see if I can get this picture to upload
1BADI5
DMV
Why do I keep getting photo is to large errors........same camera and it's a smaller file WTF
On another note I need to call FAST and order a set of injector lower O rings as where they use a special size........I don't reuse injector O rings.......quick way to burn your car/truck down
jroyer87
Has anyone swapped 2nd row seats from a Tahoe to a suburban?
I have a 2011 Tahoe with heated/elec folding captain chairs. Been hunting a bench seat. Finally came across the grey bench I’ve been looking for but it’s in a suburban. Just not sure if they will fit.
has to be the same wheel base tahoe/yukon suburban/yukon xl, etc
wjburken
Eastern Iowa
Tahoe seats and Suburban seats are not compatible. Have to stay within the same wheel base. Tahoe - Yukon - Escalade is ok. Suburban - Yukon XL - Escalade ESV is ok Tahoe to Suburban is not.
jroyer87
That’s what I was afraid of. I’ve heard of people making them work but hadn’t seen any real info on it. The search continues!
Is it possible to just swap the lower seat frames only? So if you have a bench in a Tahoe and want to swap to capts from a Burb--can you get lower seat frames from a Hoe to swap onto the Burb capts?
jroyer87
The bench has a center support also so I don’t think that will work. I believe I’ll need the correct carpet also for the swap. If I could just talk them into doing a test fit. Lol
wjburken
Eastern Iowa
That I can't speak to. As @1BADI5 said, its probably possible, but not sure the effort is worth it.
wjburken
Eastern Iowa
Where are you located? I am seeing a lot of bench seats on eBay. When I converted my 2007 from Captains to Bench back in 2011, I was able to get a decent deal on eBay shipped.
Waited for prime day to see if this went down in price: https://www.amazon.com/gp/product/B016Q4Y5CM
nope.. :(
Youtube channel: South Main Auto has one, looks so compact... :D
F it, the ** is getting some suspension work once i get the oil pressure happy. :favorites37:
Ordered! :gr_guns:
Image from one of the reviews,
I have been thinking about buying a cordless impact but decided on this one thanks to you. The others were $200 without a battery and are big. I like this compact design with about the same torque.
wjburken
Eastern Iowa
I like it. Will you be able to turn it on and off or would it be on whenever your headlights are on?
Will definitely make it easier for the LEO's in your area to spot you.:driver:
lol, it would be wired up to the running lights I don't think I would want a switch necessarily
jroyer87
Northeast Texas. I come across them all day long but I have they light grey interior which has been hard to come by around here.
dizhai
