massivespl
I'm not mean, I'm honest.
Michigan
26s35s vs 24s33s
St. Louis
Dropped the spare down looking for that stupid noise. I thought maybe since I had it down for my axle lube change that I wasn’t seated correctly. Nope, not it. I will have to take the liner out of that wheel well and find some help that can search while I make the noise happen. WTF!
Broken heat shield maybe?
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
Maybe. I have wiggled and pulled on everything imaginable under there. I do see one shield that will need repair but that one is not making the noise.
One of my coworkers is going to help me find it today. I will keep Yall Posted.
5strmtrp
Worked on Lola some more. Traced the disconnected Console and Trunk power cables. Terminated the 50 amp Console feed with a powerpole. Then connected the smaller power feed to one of my ham radios. Tidied up the cable bundle. Afterward reconnected the two feeds to the 125 amp megafuse.
View attachment 258950 View attachment 258951 View attachment 258952 View attachment 258953
Ok in this pic, the plastic panel closest to the gas pedal. Does yours have a part #, mine is missing, messed up part is I have somehow torn my pants leg 3 times on it.
Also the wiring that u pulled out, any idea where the go to under the dash. I’m trying to reuse them to power my fog lights and lightbar soon to be installed on the front of the truck.
Idriveaho
I drove it home after it being held at Belle tire for 8 damn days cause my warranty company keeps jacking me around and not paying up. Long story but I’m pretty sure I’m going to have to sue to get my 1995 dollars back for a company that won’t do what they are in contract to do.
Sam Harris
Do not like. Wtf is the story here?
Sparksalot
Bastrop County, Texas
Sparksalot
there are two sources in the pics above. The heavy #6 labeled console, and the #10 red/black stripe. They both go straight to the battery terminal block.
The pic below is from the 2011 the wasn’t so kindly decommissioned. The terminal block is the same.
I found the GM upfitter manuals to be IMMENSE help in tracking these down.
Care to share the name of this shady warranty company so others don’t buy it? I myself don’t believe in those shady outfits, I don’t trust them to pay out. Now I see even Ice-T is plugging for one on TV.
5strmtrp
I do have GM’s upfitters info, in fact the diagram they show on it is the same as what I found in the glove box. It’s the small 22 ish guage wires I’m wonder if they did power the lights upfront in the grill and the strobes in the headlights.
I’m trying like hell not to run more wiring thru the firewall if I can power and run the fog lights and lightbar.
George B
¯\_(ツ)_/¯
Still searching for the rattle or pop noise. I decided to try flexing the body and frame a bit to see if it would help. Found a good loading dock and drove one front wheel at a time until it lifted a rear wheel. No change.
I did manage to test my G80. Works good. Locked it and continued climbing until I was teetering on one front and one rear wheel.
That would've been a cool pic.
Replaced the rear liftgate window switch in about a minute thanks to a video a member on here made some time back. Bought a fuel rail adapter and an ethanol test kit (little beaker style bottle) to check the actual alcohol content of my fuel. Last time at the station, the content dropped 20% into the 40s and it should have at least been in the 70s. Either we're getting cheated or the computer got a math problem wrong.
worleytrev93
