2004 6.0 NV4500 Tahoe
I remember reading your review on Vinci awhile ago and it stuck in my mind. I think I'm fairly sold on using the 224/228 I have and then getting with Vinci for a custom cam for my Silverado where "Max power" is more important to me. Plus I don't want to wait for a custom cam. I think I can have this thing together sometime next week/weekend depending on my choice of what to do with the heads.
Also on cam consideration, it's difficult to find much info on cams for something heavy and stick shift but in the short time I had the 224/228 in my Silverado it drove very well out of boost. Plus it sounded cool
If you were to ask Roger about a cam for a heavy ass SUV with a manual trans I’m sure he would be full of answers. The guy is super smart. He designs/ engineers their cams. But I understand your time issue too.
Ok as I ponder the meaning of life this morning I realize I need help deciding what I should do to this thing.
Things I need help deciding on:
-ARP head bolts or go straight to studs?
-Replacement LQ4 or LS9 gasket?
-Trunion Upgrade?
-Keep the sissy 212/218 or go bigger?
-If I go bigger throw the 224/228 I have in it and custom spec something for my RCSB or custom spec something for this?
-Have 862s worked over like it had before or throw the PRC heads I have for the RCSB on it and get something different for it?
-Other crap I'm not thinking about.....
With as much as you open engines, I'd be inclined to suggest studs. But, ARP direct-replacement bolts at least.
Stock replacements are fine, unless you plan to boost.
-Trunion Upgrade?
Absolutely. Any time you go above stock spring rate and cam size, you should upgrade the rocker bearings.
The 212/218 is a mild cam in a 5.3, so it's even less cam in a 6.0. If you have a larger one available and you already have the engine torn down, go for it. Anyone doing a mild 5.3 build or AFM delete would love to take that sissy cam off your hands if you had no other use for it.
something for this?
All depends on what you want for each vehicle. As far as low-end grunt, that 224/228 is about as big as you'd wanna go. But, yours is a manual and has 3.42s so you can afford to get a little wilder with the cam. If you're fine with "just a little more" in the Tahoe than what you had before and you really wanna get it back on the road ASAP, roll with it. Save the donkey dick camming for the RCSB toy.
Again, depends on what you want out of each vehicle.
Do stuttering people stutter when thinking to themselves?
If you try to fail, and succeed, which have you done?
How do you respond when someone says you're in denial, but you're not?
The guy that discovered milk- what was he doing with that cow?
If you hit yourself and it hurts, are you weak or strong?
Are oranges named "oranges" because oranges are orange or is orange called "orange" because oranges are orange?
WOW! Some things to think about.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
First an update then I'll get to @iamdub awesome response. :happy175:
Machine shop is bumping me to first in line and I might even have the 862s back this weekend. The 224/228 is going in because its here and @randeez and @Rocket Man made me.
I got everything torn down except moving the ac compressor and pulling the front cover. Need to do a garage clean up before I tear anything else down. With any luck this thing will be rolling mid next week.
Oh and my thumb is doing good I'm glad the valve waited to drop until the day after the stitches came out.
View attachment 257831 View attachment 257832 View attachment 257833 View attachment 257834
Better wrap that thumb up!
Oh hell I forgot about the thumb so yeah glad that’s healing good. Too bad an engine can’t self heal, that would be awesome.:cool:
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
They only stutter when they do.
Yes
I plead the 5th
Something naughty for sure.
What's the smallest bone in a goat? The terrorist :Jedi:
Orange rhymes with door hinge.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Yes mother.
It's honestly been 99.9% painless since the stitches.
Pulled the firewall insulation down and I so badly want to clean the engine bay it's just not possible while it's in my shop.
Yes mother.
I just cleaned up my front undercarriage since the diff is out. It’s in my driveway though- I don’t have a big old garage or shop like you rich folks. Plus I washed the little bit of ash that’s fallen on it in the last few days. Now if I can just get parts delivered. Stupid smoke.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Can't get parts because of a little camp fire? That's really annoying I'm hoping mine come this weekend.
Bad part about my tin can shop is the idiot that built it sloped the slab away from the doors so it floods very easy. Absolutely cannot bring a hose in there Haha.
Also if the idle doesn't have the sound Im looking for with the crazy quiet exhaust that's in it now it will have to get some changes.
Too bad the Kooks off-road Y I’m selling is not for a NBS or I’d try to sell it to you.:)
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
I've considered getting a catless Y pipe but it already smells of unburnt fuel and I don't want to make it worse. I think it has a set of highflow cats now or they are dummy cats, either way my current y pipe is all V bands and I love V bands!
Mr. Vinci has officially emailed me back and asked me some additional questions. Surprised he emailed back so quick!
Yes
I plead the 5th
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
@Rocket Man Your Bromigo Mr. Vinci responded with his recommendation and it makes me feel good about using my 224/228 .600/.600 113lsa.
Thanks Dan,
So with this and the other information in mind along with your goals, my recommendation is: 578/587/222/228/114+4A built on our “rapid ramp” lobe profile. Preferred range: 2700 to 6700. This combination will provide about 85 plus HP and like torque. It will have a pretty aggressive idle which can be adjusted to be rougher or smoother via HP tuners. Street manners should be very good because of our exclusive ramp profiles. While I could easily push the lift up over the .600” mark, tests have proven the factory heads just won’t flow much more when the lift is higher than .585” so why forfeit valvetrain longevity? Also, while extending duration is easily accomplished, it is a daily driver, not a weekend drag truck. Some common sense must be used when specing out cams for this purpose. Since all of our US 5150 steel billet cams are built on CNC’s, our cam specs are pretty easily adjusted. If there is a reason you feel you needed more lift, a duration change or LSA modification, it’s is easily accomplished.
Let me know what you think. I’ll be honest with you with my answers.
Regards,
Although my cam is not exactly what he speced it is very close in many ways. The lift is marginally different and if I do eventually end up with better heads the cam won't be lacking in lift. The exhaust duration is the same and the intake is only off by 2 which would warrant a slightly more aggressive idle in the Vinci cam but would be tamed out a tad by the wider 114lsa. So I think my choice is good and I will certainly consult him in the future.
Also I should add I'm not a cam guru at all, the above guesstimation is just my thoughts after reading a book and many internet posts about it. Please don't take any of my babble as fact.
worleytrev93
