Thanks. And sorry I do not , the builder did it . It was just my ideas . Also he added red to the dots , that was actually his idea lol. Great touch imo .@05Single THAT IS SEXY.Could you link me to the films you used?Also the KM/H delete was a very subtle change i didnt even notice that.
My guess would be the solder might need to be reflowed. I don't think a bulb is used to light that display.Looking for some advice here....I am looking at an 01-02 gauge cluster that the odometer screen does not display. Is there a light bulb that illuminates that display that can be replaced, similar to the rest of this cluster with the small blade bulbs? If not, does anyone know what causes the odometer screen to not display? Thank you in advance.
BTDT on my own cluster although it was an 03 Denali XL and a 04 EskyThanks for the replies so far. Hoping someone who is positively in the know will weigh in on this question. Someone who has been here and done that already. I suspect you both are correct, but it's just speculation for all of us who haven't BTDT. Thanks
Yes very common on the 03 and later clusters. I believe the fix is to reflow the solder on the 03 and later. My 04 Tahoe cluster is dim.BTDT on my own cluster although it was an 03 Denali XL and a 04 Esky
Read through this thread, gives me some ideas, but questions I have;
1) How many bulbs are in the instrument cluster?
2) One post here says you need to solder them to the board. Can't you just by the PC194 (or whatever size it is) LED's that twist and lock in to the board? My '99 is that way. It was 6 or 8 PC194's that I switched from regular bulbs to LED's. It took longer to R&R the cluster than it did to switch bulbs. No soldering needed. Or is it that these are LED's to begin with?
Read post above yoursAre they bulbs or LED's? If they're LED's, then I'm not going to touch them.
