SLP resonator delete? 2015+
nglauer
nglauer
just ordered it for my 2019 off amazon, so free return if I cant get it to work. It will be here Friday. It will be paired with K&N CAI, Range device and open butterfly valve.
Definitely following.... Hopefully it'll be a direct fit. Thank you for trying it out! Looking forward to your updates.
Sent from my SM-N975U using Tapatalk
nglauer
nglauer
I deleted the muffler on my 2017 Suburban but left the resonator. Sounds decent but the drone is pretty bad.
I wondered about that. I used to have a 4th generation camaro and trans am.... I literally tried every exhaust you could imagine trying to find one with great sound and no drone. Corsa was literally the only one. I don't want it to drone bad.. not with my kids occasionally riding in it.
Da90
Tulsa, OK
Yeah it’s enough drone to make me want to buy a muffler. Any suggestions? Lol
nglauer
nglauer
I can't speak for the Corsa system for the Tahoe/Yukon's... but I was very impressed with the system I had on my cars. If I had the money, I would own a new Corsa for my Tahoe as well.
As for the drone without the muffler, I'm honestly not sure. You could probably do something like dynamat on the floor, but for the cost and hassle adding a different muffler may be easier.
Someone else may have better advise that has traveled this route.
Nick
Da90
Tulsa, OK
Nick
Yeah I’m just going to add a muffler. Just not sure which one. I need to do some research.
juicedgsr95
North Carolina
Well its definitely not a direct bolt on for the 2015+. BUT I made it work. The tips are kind of sunken in, would like them to come out a little further. Will end up cutting off the hanger on the new pipe and welding a new hanger on to line up better instead of the rig job ive got going on now.
nglauer
nglauer
View attachment 256405 View attachment 256403 View attachment 256406
Do you have a picture from the outside/side? Looks really good. Did you notice much difference in sound? I definitely want to do this on mine as well.
juicedgsr95
North Carolina
To answer your other question, sound wise, just a slight difference. maybe more outside the truck but I havnt had anyone drive it for me to hear.
That looks great! and since we have the same wheels/tires and matching black paint... now I have a better idea of what it'll look like on mine! Thank you for testing this out! I see this being my next purchase since I scored new take off skid plates off eBay.
STORMIN08
i really think that if you loose the connections and play with the adjustment, you caould get that to sit a little better.
the pipe itself looks rotated, and causing an angle to the hanger...roll that slightly, then correct the tip to liking of the body angle.
other than being under the panel, it doesnt look bad, just needs a slight tweaking
Prospect62
Central NY
I was thinking the same. I think with a different rubber hanger and some bending of that metal hanger I could get it to look almost perfect.
STORMIN08
i didnt catch the addition strap...even at that, remove that piece and lengthen the hanger rod itself, should be an easy fix. i add and alter hangers regularly.
Prospect62
Central NY
Well...I don't have access to a welder so for me, coming down with longer rubber instead of going up with a longer rod will have to do. I'm thinking it should work.
STORMIN08
it will, most hardware stores should have a SS rod similar in size, then hit up an exhaust shop...should be about 50 bucks total. maybe a hundo in this economy
vsaravia
