Spent about 4 hours under it trying to figure out how I'm gonna do my crazy ass exhaust. Well, about 2 hours of that time was working on the valve.
Made cardboard templates of each of the mufflers to figure out orientation. The smaller one I'm currently running is a centered/offset configuration, the long one I'll be adding is centered/centered. Was trying to determine which one should go first and how it and the valve will be positioned. It looks like it's gonna come down to me modifying the cross member for the extra space.
Yes, I'm still working on that damned mower... Sometimes.
So far, I'm thinking this is a winner. Put the bigger one first and angle it and the valve as pictured so that I can tuck it up as high as possible with nothing extending below the frame rails with about 1/2" to spare. The second muffler will be clocked the same. The 3" straight pipe will run parallel. It will be on the ground/far side of the system so the mufflers will act as a sound barrier between it and the floor of the cabin. They will merge together right at the arch that goes over the axle.
I also tested out the DPDT rocker switch on the valve. I'll do all the wiring at the switch so I'll only have to run two wires to the switch (12V+ and ground) and then two wires (+ and -) from the switch down to the valve to have bi-directional control.
