Stale smell & leaking noise from sunroof every time it rains
Allyssa
I have a 2015 LTZ Tahoe and I've noticed that every time it rains, the interior smells musty, like old wet carpet but nothing seems to be wet. When driving, I've also heard a leaking noise that seems to come from the sunroof. Is there a drainage system in the sunroof or somewhere in the door/roof area where rain could collect and drain?
This happens every single time it rains, especially the smell. Any ideas?
There are hoses that duct water from a "gutter" in the sunroof down the A-pillars and through the cabin wall or floor. They can get clogged, especially if you live in a dusty area. But if you're hearing wind noise while driving, the seal may be collapsed, worn or damaged. Next time you drive and you're just under the speed where you start to hear the "leaking noise", gently push upward on the glass to see if that same noise occurs. If so, then you have a seal problem. The water may be running down to somewhere that you can't see, where it stagnates and mildews, causing the smell. There's heat/sound insulation (jute padding) under the carpet that would absorb most of the water so the surface of the carpet would remain dry. You'd have to snap off the trim and pull back the carpet around the door sills and kick panels to find the wet area(s).
A
Allyssa
Thanks for the input. Are you saying push on the windshield to test?
NO! Not the windshield! The sunroof glass.
When you said "heard a leaking noise that seems to come from the sunroof", I assumed you meant you heard a wind noise while traveling at highway speeds because I've had this happen before on a past vehicle. If you hear the noise while going around 60 MPH, go about 50 MPH then gently push up on the sunroof glass with your hand to see if you hear the noise that you hear when going 60 MPH.
Tupapi
