Side Letters Removed
ClaytonFLong
Clovis, NM
I just removed both sides of front door and rear door letters "TAHOE" and I was wondering if anyone went ahead removed the side trim as well to create a smooth look? If so, does anyone have pictures that I can see so I can decide if I want to remove the side trim on the Tahoe. Thanks
ClaytonFLong
ClaytonFLong
Clovis, NM
Thank you for the reply. And did I mention that the “Wonder Wheel” is magical at removing the double sided tape?
wjburken
Eastern Iowa
I like the look of no door molding but it does expose you to door dings. I did it on my 2007 Silverado after they started to come off on their own and loved the clean look. Here is a picture I found of a black Tahoe with no molding.
ClaytonFLong
ClaytonFLong
Clovis, NM
I like the clean loook too. Many cars have them now and I’m debating as some front portions of the trim are starting to come off and I can see the glue/tape behind behind them.
mikeyss
Longmont, Colorado.
Picture from last year, buy here's another picture with no moldings. Just be careful, when I removed mine, I found corrosion under it and it almost ate through the door. I had to have all 4 doors repaired/repainted.
This was when I first removed my strips.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
I took them things off and haven't regretted it. :) Left the Tahoe word on there though, didn't have the heart. Did loose the GM badge in front of them. They were worn out and looked like chit anyways.
cfmistry
Ugh the stupid side moldings. I like the look of them, they break up the flatness of the door so they help hide small dents. But mine are pulling off and starting to look ratty. I don't think they'll stay down if I just retape them.
PG01
Up here to the right
89Suburban
SE PA
Do you have any pics of your truck?
:lol:
:yaoface2:
Ok, I'll be the contrarian. I like them on, because if the truck has no moldings, it looks like a stripped-down fleet model LS. Very common on the 2500 trucks.
I'll take debadged, retaining the moldings.
That's a BITCHIN Suburban. :)
MD Tahoe 13
View attachment 254315 View attachment 254316 View attachment 254317 View attachment 254315 View attachment 254316 View attachment 254317
Do you have a body lift your Tahoe or is that the standard height?
I am looking to put the Tahoe badge/letters onto my doors (no molding; was an SSV) but I can't find the exact location on the door to put the letters on. Anyone have a GM reference or measurement? May have to just go out and find someone's Tahoe and take measurements myself unless someone already knows.
89Suburban
SE PA
Standard. I would mind 2 or 3 inches lower in the rear.
ClaytonFLong
ClaytonFLong
Clovis, NM
bluekenworth
