Bowtied
Hi y'all!
So I got a 3.5" RC kit installed on the '07, love the look and have no issues running 33x12.5's on 20x10 with -19 offset.
However, when it comes to alignment, with stock struts and spacers installed within the kit, the toe is straight (it drives straight) but the caster has no room to be adjusted and is off meaning the wheel won't roll back like normal.
Also, the ride is pretty bouncy - I've gotten somewhat used to it over the last few weeks, but it handles bumps realllly bouncy and shoots angles when hitting them, also gets loose braking. Doesn't handle very plush and sits slightly more than level in the front end.
When I looked at the kit install, I noticed on both the passenger and driver side front - the new RC UCA's had a rear pocket cut for travel but not the front pocket (or towards the front of vehicle, or right side as seen in photo *passenger*) -
If I cut both of those droop stops with a grinder, will I potentially get some amount of suspension travel/squish back up front? Will the front suspension run into any issues by not having that metal cut off, considering two fo the 4 pockets have already been cut? - Thanks.
