Got my 2010 PPV
GreyStone
I'm kinda diggin the Hybrid front end... IDK why but it's sweet looking IMO.
1BADI5
1BADI5
DMV
Ohhhh. From what I've seen the hood doesn't appear to fit without the whole front bumper. The hybrid bumper is curved on the sides of the grille and not as wide as our flat fronts. The hybrid hood is going to hit the edges of your grille. I have a few pics. First is a hybrid and a regular tahoe side by side so you can see the difference. Second pic is a suburban with a hybrid front bumper but a regular hood. You can see the gaps around the more narrow hybrid grille
Sent from my SM-G973U using Tapatalk
Dude, your a lifesaver....... I owe you a six pack for that assist. That side view pic was the money shot.
I called and cancelled the order on the hood .......since they had not even pulled it yet, they cancelled the order and no restocking fee.
Well that's some money back into my slush fund LOL
STANKHOE
Maryland
I'm glad I caught it in time lol. I remembered seeing this before. Its good they let you cancel with no penalty
1BADI5
1BADI5
DMV
Yeah since they had not pulled the part and the payment was still pending, he said no worries.
kbuskill
NE. FL.
Well I hate to say I told you so... so I will just say that I'm glad you didn't waste your money and they were willing to refund you without a restocking fee.... lol
1BADI5
1BADI5
DMV
Its all good
kbuskill 1 - 1BADI5 - .5 lol
1BADI5
1BADI5
DMV
Well since I have not thrown any updates in here in awhile.
Got some parts powdercoated in Illusion Lime Time.
And I have been working on my LSA blower, hoping to finish it up over the winter and install in the spring
IMG_20201215_150150.jpg IMG_20201215_150126.jpg IMG_20201215_150134.jpg IMG_20201215_092614.jpg IMG_20201206_162153.jpg
1BADI5
1BADI5
DMV
Guess I still need to add all of the pics and specs on my AFM/VVT delete and heads/cam built that I did back in October.
In the last couple weeks I knocked out the Circle D 3200 stall billet torque converter. This week will be the right sized (body) injectors and tune..........right before Christmas.
PPV12HOE
NC
You redid the valve covers....? I thought they were red...
1BADI5
1BADI5
DMV
Project name "Undercover Sleeper"
Completed (as of 01 FEB 2021)
- Dyno Tuned at LMP, Baltimore
- TSP Stage 3 5.3 High lift cam
- RPC Stage 2 heads
- BTR .660 springs w/Ti hardward
- Michigan Motorsports 3/8 pushrods 7.400"
- Michigan Motorsports rocker arms with trunion
- BTR VVT delete kit
- TSP AFM delete
- Katech C5R timing chain
- LS7 Lifters (OEM AC Delco)
- Texas Speed Long tube headers - 1 3/4 primary/3" collectors
- Texas Speed 3" catless Y Pipe
- Magnaflow muffler 12259
- Rear resonator delete
- Snake Eater Performance 102mm TB
- FAST LSX/rt 102 Intake manifold
- AiRaid MIT intake tube / AEM dry filter (70k)
- Airbox mod (opened up inner fender and matched the Airbox)
- Powerbond 25% under drive balancer w/ ARP crank bolt
- LSX Innovations - Light weight Alternator/PS pulleys
- Cleaned the MAF (83k)
- HPTuners - work in progress
- Denso IR plugs / Taylor 10.4mm plug wires
- Gates HD Green belt, AC belt, idler pulley, auto tensioner
- Atomic Fab Performance solid motor mounts
- UDR Catch can
- AC Delco Professional 48 series Battery (3/20)
- Royal Purple HMX oil change (70k/75k)
- Royal Purple 75w90 Diff service
- Circle D Billet 3200 stall converter
- Tru Cooler MAX - 40k Trans Cooler / with custom brackets
- B&M Deep Trans pan - extra 2qts with drain/temp sensor ports
- Trans service (OEM fluid/filter/gasket) (4/20, 75K)
- Replace both Trans cooler lines (AC Delco)
- StopTech SS lines (front/Rear)
- DOT3 Flush
- AC Delco PPV front rotors
- EBC YellowStuff front pads
- Rear pads
- Aerotech gauge with column pod
- Innovate Wideband (in, 4x4 headlight bezel)
- XTRONs HU with backup camera & forward facing camera & GPS
- OEM Remote Start added - RPO AP8, GM part 19154445
- OEM Auto Dimming rear view mirror
- OEM mirrors with signals/puddle light - *needs BCM update*
- OEM DIC install
- OEM Tow/Haul shifter
- OEM Steering wheel Stereo controls
- Grant Leather wrapped OEM wheel w/ fresh OEM spoke covers
- Husky mats - front/back/cargo
- GoRhino push bar
- New headlight housings w/ LED HI & Lows
- OEM foglights added - OEM switch/lights and wired
- LED light bar, LED tag bulbs, LED brake lights, LED Dome lights (red)
- BellTech 2/3 drop (spindles/springs)
- OEM front strut/mounts and rear shocks
- Hellwig adjustable rear endlinks
- Yukon Gear&Axle (3.73 and Dura Grip) (Complete overhaul/rebuild @ 75k)
- Spohn rear LCAs
- Spohn adjustable Panhard bar
- AC Delco Professional front sway bar end links
- Goodyear Eagle Ultra Grip GW-3 - (265/60R17)
- Airhorn install 150+DB
- Dropped the spare tire out, deleted the spare hoist/holder, removed OEM bottle jack and tool kit, removed the spare battery tray, removed about 5 lbs of spare antenna cable from the rear of the truck, removed excess brackets and cabling from under dash
Next up - Winter 2021
* GM 20 declads - at shop for Powder / 295 45 20 Pirellis
* L96/6.0 - tear down done
Spring 2021 -
* Install 6.0
* Finish LSA blower
Dantheman1540
Sugar Loaf Mountain
I usually don't swerve over to the GMT900 stuff but how do you like those Atomic solid mounts? I love the Polys but figured the solids would vibrate your teeth out.
1BADI5
1BADI5
DMV
Dan - honestly they're not that bad. Way better then having to replace motor mounts annually LOL
SATXFD
Can you tell me the Part #s for the 4 Stop Tech S/S Brake Lines for the Rear of a 2012 Tahoe PPV?
Thanks,
SATXFD
BadDaddy2003
