adventurenali92
I agree with @TheAutumnWind , a trans cooler upgrade is definitely the way to go!
Personally, I have never had need to try and find a larger radiator. That being said, a very quick search on Rock Auto, found that the same radiator from spektra is used in the '07 Yukon XL 6.2L 1500, 6.0L 2500 and Sierra 6.0L 2500. The 6.6L D-max Sierra 2500 uses a different radiator. Chances are, that the D-max radiator has more cooling capacity, but should probably bolt in.
You could order one for the d-max from Amazon and see if it fits. If it does, then you have your answer, if not returns are pretty painless with Amazon.
@ 100 degrees ambient I was seeing ~190* trans temps when stock in stop and go traffic.
Okay, so even if that is normal, why in the hell is the engine getting over 210* sitting at idle for a couple of minutes? On my way home, I stopped and grabbed my toy hauler from it's storage which is about 5 miles from my house and is flat terrain. The engine temperature reached a little more than half way between the half way line and the third quarter line, so somewhere around 220* to 230* with the air conditioning on. I turned the air conditioning off for the half a mile or so which is a school zone and then into my neighborhood. When I did this, the engine temperature dropped back down to around 215* or so, still slightly above the 210* half way mark on the gauge. I am afraid of the truck overheating while towing my toy hauler this weekend. Should I be concerned or should I just tow as much as I can with the air conditioning off, especially up the the grades and just take it easy? The only grade I am concerned about is 9 miles long at a 6% grade.
Thank you!
I was getting s steady ~220* in stop and go traffic when it was 110* last weekend. Left it idling running the a/c that day and I saw about 200* trans 220* coolant. That is with an upgraded 12x12" transmission cooler, in a recently flushed system with a brand new waterpump.
You should always have the air off when towing up a grade. That's kinda towing 101. My 6.0 has been doing the same thing the last week or so with warm temps and driving through the construction zones and stop and go. Warm temps outside, my trans gets to about 190ish and my operating temps get right on the 210 mark. Just take it easy towing your trailer and try not to hammer it.
okay your coolant tempshould always stay just below 210 always if it ever goes above 210 something is wrong doesnt matter if your towing idling or just driving
ive got 240k miles on my suburban and here in arizona ive sat for hours running the ac full blast when it was 115 dagrees outside and the temp stayed just below 210 and never budged
now the ac may start blowing warmer air but thats it engine temp stayed the same
now its very important for the cooling system tomaintain 15psi this raises yer coolants boiling temp from 212 to 245 dagrees water boils at higher temp under pressure
every time ive had this issue in the past ad cant seem to located the source of the problem it usually winds up being a leak somewhere it winds up being a tiny and obscure hard to find leak
the affectiveness of your cooling system depends on its ability to maintain pressure roughly 15 psi
Thank you for your reply. While I don't necessarily disagree, if you're referring to the 2001 Suburban with the 5.3 liter in your signature, your engine is different than mine. Regardless of being a 6.0L, even the 5.3L from my same year is different. The 1500's in my same year have electric fans as one major difference, that goes for the Yukon's, Tahoe's and Suburbans. We're not really comparing apples to apples here, especially considering your truck is 6 years older than mine and there were significant changes in those 6 years.
However, I do understand the water boils at a different temperature when under pressure. When I started this journey the cooling system wasn't holding pressure which is why this thread was originally started. Now, the system builds and holds pressure as far as I can tell. Where the upper radiator hose wasn't getting hard before, it is now, but not lock a rock hard. I am not doubting at this point that it could definitely be the radiator, especially since that's the only thing I have yet to replace. I am hoping our trip this weekend goes well and if everything works out and we make it back without any major issues, I will look at replacing the radiator next weekend to see if this issue stops.
Thank you again!
I hate to resurrect an old thread however, my problems still persist for anyone else having the same issue I am. The only thing I have not done is a proper pressure test which will be on my list shortly. Over the winter (we've had a mild winter here in AZ), the truck, while sitting at idle, still gets over 210*. I am still concerned. At this point, the entire cooling system has been replaced (thermostats 3 times, radiator, water pump, hoses, coolant reservoir, reservoir cap, etc) with no change.
