What Oil Filter Brand Do You Swear By?
  • Total voters
    37
My own research shows that K&N is superior numbers wise to Wix, M1, Fram and ACDelco. The oil pressure is higher on my motor running the K&N compared with the M1 EP filter and the K&N filters down further particles wise, 10 microns compared to 30.
You won't hurt your engine by running ANY of them. We run the K&N because we like the 1" nut welded to the bottom for removal, helps my daughters and I when changing the oil.
The higher quality filters may have less paper fibers clog up the screen under the oil pressure sensor over time which can affect the AFM system.
RaiderRodney
Burnsville, NC
Agreed, I've been using the K&N's for several years now.
79jasper
I was always curious about a longer filter, but having the nut on the bottom would mostly take care of that.
Interesting that the k&n filter finer, plus has higher oil pressure.
Merc1973
Maryland
Fram Ultra Synthetic with Mobil1. Been used on this truck since first owner. 277k
Look up the youtube vids of cutting them up. This one is hard to beat.
alpinecrick
Western Slope of Colorado
That's because the K&N (and various other synthetic filters) begins to restrict flow with any heavier viscosity than 0-20.........
SnowDrifter
Sasquatch Country
Fram ultra synthetic. Wouldn't touch the others with a 10ft pole
Amsoil filters
It would have to be dire circumstances for me to run anything other than those two
TheEnder
(*******) Fram Ultra Synthetic.
Mudsport96
40.923,-89.488. Illinois
I run delcos on my GMs and the seem to do well.
On my old 302 ford I run Mortorcraft, it has nearly 300k on it and I've tried different filters over the years and the FL1A motorcraft has the highest initial pressure and stays higher longer over the oil change intervals. I kinda wish I could find one for the 5.3s so i could test how they do on a GM.
The tahoe does 30ish hot idle and 50 on the highway at 130k and the Silverado is 20ish hot idle and 30ish at speed with 400k. Both with the recommended delco filters. Wix doesnt do either of those pressures. And I wont run frams I've had cans split and filters collapsed on my vehicles over the years.
Drewphil
