The BIG stereo install
TARDIS
Jersey Shore
@Squirrelsmith
Your audio build out is great.
Where did you pick up the speaker lines for the rear?
I'm looking to hide a 2 Way Crossover; LP to the hidden sub (150-40Hz), and HP to the 2 replacement 4x10's (600Hz+)
Do the LightBlue,Dark Blue, Yellow, & Brown rear speaker wires run along the Driver or Passenger side? Are they under the window or under the carpet?
Thanks man, your help on the Cruise Control stalk was great!
Squirrelsmith
Squirrelsmith
@Squirrelsmith
The rear speaker wires go from the speakers to the drivers side along the roof and then turn the corner down to twards the carpet. Cant remember where they go after that, i didnt use them
Squirrelsmith
Squirrelsmith
So i realized that i put my ground to a panel that looks suspiciously like its glued in. Did a voltage drop test and got about a %4 drop wich apparently is right on the edge of acceptable. So i redid the ground wire through the floor.
TARDIS
Jersey Shore
...This thread has been inspiring.
I've been trying to find a hidden spot for a MidBass tube. Something that won't take up Cargo Area on family roadtrips.
I was thinking about loading a small MidBass Sub. I was trying to figure out an enclosure within the 8" wide x 20" deep slot.
Instead I'm using the space to hold my crossover.
Still trying to find the best spot for a small MidBass Sub, that's out of the way.
Squirrelsmith
Squirrelsmith
seen guys use the center console
Andylbc
