05Single
afraid of the dark
Out with the cracked glass , $25 later in with the new.
GJones
ATL
In all honesty I have to say you should get an OEM used harness and relay pack and return that one. There’s a member here (@ScottyBoy ) who gets them, cleans them up, re-looms them and sells them for about the same price as that one. All of the aftermarket ones have a tendency to melt when it gets real hot, like 100* days. Nelson, LS1 Fans, etc. My LS1 Fans harness melted when I was 150 miles from home on a 102* day and stranded me. I rebuilt it with 80 amp relay blocks and heavier wire and it melted again. My OEM one has been going for 2 summers with no problems. It’s a different design than the aftermarket ones. I wish I’d known before I went through all the crap I did. Just a heads up.
Guess it’s a good thing I kept my original fan. Haha
Saw nothing but positives on here about these guys.
Nelson Performance is allright I guess but Google “ Nelson performance fan harness melts” and read up, then take into account what you read coupled with my experience before you install it.
Actually most of those threads are old.But it’s well known that plenty of the aftermarket harnesses melt.
Before I bought mine from @ScottyBoy, I had bought a new aftermarket harness from one of those companies that sells them--forget which--but once I started getting and reading feedback about the aftermarkets, I sold it. Def don't want an important part such as that failing on you at the worst moment, possibly ruining your motor. Or worse, your truck catching on fire.
GJones
ATL
From my quick search at work the latest I’ve seen about them being bad was 2015. But I definitely got mot searching to do.
Not that it really makes a difference, but this is the company's harness I went with. It looks really good, labeled and everything. But look at the gauge wiring, along with the complete package. Compare it to oem. Stick with oem.
Sam Harris
Recorded a cold start video, post-BBP tune:
Now I REALLY want my cam... [emoji16][emoji631]
Trying to decide if I want to replace heads or not.. I was planning to get a BTR or TSP stage 2 cam, but don’t want to lose any low end tq. And I think any stage 2 has that consequence even a slight loss. [emoji53] so either getting springs and cam, or a whole head set. Eventually I’d like to SC her, but I need to get a plan together for the pieces I need to assemble.
Sounds like you have a small cam in there already! Sounds good. Stock exhaust?
Sounds good Sam!
Got my truck back from body shop that was fixing the holes that were in the roof. Started installing Esky roof rack!
Also pictured are the wheels that I’m looking to get center caps for.
How'd they fix it, and was it expensive? Come out good?
Dud you try the company's website for the center caps? Missing one?
Bear77
South FL
I’m not sure, really don’t know anything about body work except from what I recently learned from @Rocketman and to remove and replace parts! As for the wheels, I have no idea who made these, so it’s been a mission trying to find the center caps. But not going to give up until I find out!
Drewphil
