How did you get that much chop to the idle? Who did the tune? That’s what I’m trying to do with my Silverado but it seems like there’s no chop, I’m not happy with Justin. I still need to install the headers but still, I should be hearing way more chop.
GM did the tune (stock lol). The open exhaust may make it sound meatier than it really is, too.
I put "open headers" in the title but, more accurately, it's open Y-pipe. I gotta cut off the ball-and-socket connection and weld on my factory flange. Then I'll cut it off again later to install the electric cut-out. lol
I plan to finish the exhaust Saturday morning as I have a tuner lined up for Saturday evening. I have a laundry list of what I want and maintaining as much chop as reasonably possible is on the list.
...Or maybe my buddy lied about the cam specs. lol
I guess I’ll see if I can fit my headers in. I have a feeling it’s gonna be a lot of cutting and welding on the y-pipe to make it sit up high enough to clear when it’s aired out since the frame is about half height and it needs to stay flush with the bottom of it.
This was actually last night, but I took it back out to announce to the neighbors that the lunatic on the street that mows after dark had wheels again:
Idle vid:
DAMN!! Sounds mean. Should've revved it a few times. Do you have a cam? I forget now. Sounds like it. Is that with that cut out open?
Doug118
Did a bit of frame notching
Ain't nothing but a little sectioning of the legs. You'll have to disconnect the rest of the exhaust, like at the joint just after the cross member cuz that part will need to be slid forward a couple inches to maintain the angle of the two legs. Then just add a filler piece to make up for the length.
Sounds easier said than done, but that should be about the gist of it.
I have a "revving" video I'll post up eventually when I catch my build thread up. TSP Stage2 low lift is the cam. No cut out yet, just straight out the Y-pipe cuz that connection doesn't mate up to my flange.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
Got it back from the body shop and all that looks good. Got some residual rust inhibitor to clean up.
I was cleaning ip the wheels and came across a spot where the chrome has separated from the base metal and formed a bubble. I have reached out to the place I bought from and will see what they say. I trust they will take care of me but Im still bummed. Maybe chrome isn’t for me and I need to go with these.
https://www.rpmtakeoffs.com/chevy-6-22-black-silver.html
Sam Harris
Sucketh
Uhh... no. I’ll see though but to put it in perspective the oil pan is off a F body because the stock one is too low, it would hit the ground when it’s aired out. I’m not worried about from the y-pipe back, it’s just tucking the y up high enough to clear the ground when it’s laid out. I won’t know until I try it, maybe it will be ok. The rest of the exhaust will be built by a shop, it’s def not stock.
Aren’t these the same wheels you had an issue with already where one was different/ poor quality?
George B
¯\_(ツ)_/¯
Yes, it’s weird because they are new in the box wheels with all the correct gm paperwork inside the box covering the installation and care of the wheels. I know GM had their share of issues with chrome wheels over the years.
George B
¯\_(ツ)_/¯
Actually, as much as I like how these wheels look I don’t know if chrome is for me. I wanted the black machined ones in the first place.
I did hear back from the owner of the business. He is willing to swap me outright for the black machined ones I like and has only asked for me to cover the labor since I am switching all four and not just replacing the one.
Merch619
