DenaliReyes
Detroit, MI
I see it came with it’s own brackets, and I see it doesn’t really look finished. So the question remains- can you use a standard install kit like a Metra or Scosche to make it look better? They’re only about $16, might be worth a try. Scosche GM1598AB Single/Double DIN Installation Dash Kit for 2006-Up Chevrolet Impala/Tahoe https://www.amazon.com/dp/B002S0OB5A/ref=cm_sw_r_cp_tau_LOz3EbAC4FP59
I see what you see, and the answer to your question is, maybe.
Scosche has some nice ones.
ivin74
05 NBS Nali
Htown, Texas
pass side rear panel cover. theres also a module that goes bad in the same location.
you can take the panel off unplug the actuator and manually turn it to cold, or hot. need to keep the actuator on the knob to hold the knob in place. (its the one on the side furthest back. the one up further and more to the top is for the air flow direction.) till you get the part in hand if really needed. i had mine locked on heat since last fall. just never took the 15 minutes to change the part after it came in.
@Scottydoggs
Is it the one I marked up with the arrow?
What does the module do?
DenaliReyes
Detroit, MI
Any ideas where to place aftermarket backup cameras?
I managed to run the wires under the driver side trim all the way to the back. Then under the cargo carpet. I filed a space for the wire to hide under the weather stripping on the stamped steel.
Then tapped into the reverse light to turn on the camera when used.
The camera is being held by the trim, I cut a line thru the trim enough to slide in the camera stand. Did not use any screws.
Will see how long this holds.
Possibly adding some silicone the back of the camera to help with the outside elements.
Sam Harris
Possibly adding some silicone the back of the camera to help with the outside elements.View attachment 249578 View attachment 249579
I bought one that mounts behind the plate. I dig it, but a different design from yours.
05Single
afraid of the dark
I actually drilled a hole in the middle of the license plate lol. Was kinda hidden and flush . Just a little illegal but it worked lol. Swore I had pics on here but can’t find any
DenaliReyes
Detroit, MI
I'm replacing the radiator today. After driving with all new gaskets and thermostat. I guess the radiator was the next thing to go. Maybe the preassure along with the 90 degree heat killed it.
Question:
Should my radiator fan turn on ASAP after engaging the AC to the coldest/recirculate setting?
I noticed some videos saying it will turn on as soon as the ac is. Idk.
I just replaced 2 of the 3 fan relays.
Temperature gauge stays under 200 degrees.
Question:
Yes your fan should turn on at the same time your compressor does, as soon as you turn on the AC and the snowflake illuminates.
DenaliReyes
Detroit, MI
Then something is up.
I managed to replace the radiator. Tomorrow will check on the fans. They turned on after I replaced the radiator and turned the heat all the way up to get the juices flowing. But I didnt see neither turn on after I switched to the coldest settings.
Is your AC turning on, does the snowflake in the control head turn on, or does it flash 3 times and go out?
DenaliReyes
Detroit, MI
The AC turns on, the snowflake turns on. But right now it is blowing hot air. That might be another problem.
I'm looking up other posts and will have to look into the temperature sensing unit. The harness was brittle and broke off. I wired a new tail for it. But didnt change the unit. Might be bad.
The fans turn on when the compressor turns on so check to see if its coming on.
Hodmjstone
