Well, he's a college kid that doesn't know much about cars. He wasn't sure how to get to the sub and I basically showed him how to remove the rear trim pieces to access the panels
Falls under "Teach them to fish, and they'll eat for life", or something like that. Never too old to learn.
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
Helped my son replace the factory rear 8" subwoofer.
The radio has had no bass to it for a while. I told him it's either the amp (behind glovebox) is bad or the sub. He bought a new sub (Planet Audio 8" dual voice coil, ~$35).
The factory sub's surround was totally disintegrated except for a small section. The new one, after wiring the voice coils in parallel with jumper wires, fit great (had to drill new mounting holes though) and sounds great.
I actually did all the work, he just held the light and handed me tools...lol
Great sub and price, did the same to the hoe a few years back. Used on the stock amp, but I needed a little more kick so I did the bypass and ran my own amp to the planet sub. Let me tell you, this ******* sub bumps and I'm only using a Dual 600 watt amp for it.
Bear77
South FL
Was the that sub able to be placed straight in or was some cutting involved? Minus the new mounting holes!
DenaliReyes
Detroit, MI
it works.
Kind of.
Steering wheel buttons stil need programming.
also I have to add washers so it sticks out from the bezel. I might add weather striping foam around the trim to hide the brackets u see her .
View attachment 249456 it works.
Kind of.
Steering wheel buttons stil need programming. View attachment 249457 View attachment 249458 also I have to add washers so it sticks out from the bezel. I might add weather striping foam around the trim to hide the brackets u see her .
Cant you use a regular HU install kit / bezel with that?
Surprised you didn't need to cut that metal bracket behind the radio. I had to.View attachment 249464
He’s running an Android HU with no media player- it’s only about 2” deep. Look at the other picture.
Scottydoggs
NJ
@Scottydogs
Where is that actuator located at?
pass side rear panel cover. theres also a module that goes bad in the same location.
you can take the panel off unplug the actuator and manually turn it to cold, or hot. need to keep the actuator on the knob to hold the knob in place. (its the one on the side furthest back. the one up further and more to the top is for the air flow direction.) till you get the part in hand if really needed. i had mine locked on heat since last fall. just never took the 15 minutes to change the part after it came in.
I finally replaced that actuator after not having rear ac for 3 years. Turns out it was pretty easy, I should have done it sooner.
Sam Harris
I wish mine were this easy. I have a hole in mine. [emoji3525] it’s been halfway assembled in the back for a year and a half. [emoji35]
DenaliReyes
Detroit, MI
The android radio came with it's own brackets.
I should hVe meaus6the radio it's exactly 7 inches wide. The opening is closer to 8 inches.
The hu can is as far up front as possible. I want it to stick out a little more. Adding washers to mounting screws.
Now I have to figure out which app to use with it.
Now I have to figure out which app to use with it. View attachment 249502
I had a Sony Android, but sold it because I wanted to watch movies. Should've kept it. You were able to do a custom wallpaper? The "GMC"
I see it came with it’s own brackets, and I see it doesn’t really look finished. So the question remains- can you use a standard install kit like a Metra or Scosche to make it look better? They’re only about $16, might be worth a try. Scosche GM1598AB Single/Double DIN Installation Dash Kit for 2006-Up Chevrolet Impala/Tahoe https://www.amazon.com/dp/B002S0OB5A/ref=cm_sw_r_cp_tau_LOz3EbAC4FP59
DenaliReyes
Detroit, MI
The app is called agama launcher there is an option to place a logo in the center.
I'm still learning from it.
I gotta stop messing with it while driving lol
Hodmjstone
