2008 Tahoe STILL has misfire. Please send help
Chloe Golmon
Hey Y'all,
March 2020 we installed a new motor and ECM ($3500) in our 2008 Tahoe LTZ 5.3.
Took it to the dealership to have the computer programmed and they also changed an actuator in the transmission. (Got locked into park while it sat during motor install) ($2100)
Dealership also told us it had bad gas, and it would run great after we swap it out. (I call B.S. on that )
Brought the truck home Friday, siphoned the gas and it is STILL MISFIRING and having irratic electrical issues!!
We have replaced:
Motor
ECM
ALL Spark plugs
Battery
Negative battery cable
Added an extra ground from motor to frame
Siphoned gas and replaced with new
Remaining symptoms:
That damn Stabilitrak service light is still on
The gauges are freaking out
Nav screen may or may not work
Passenger running boards wont drop
There is still a shake in the motor
Running codes P0315, C0561
Background:
Fall 2018 took our 2008 Tahoe LTZ 5.3 to the shop for a serious shake while driving. They said it was lifters. $2400 later, lifters were replaced and the truck was still shaking. We were told it was cylinder damage from dricingnwith a misfire and we had to get a new motor. Mechanic literally told us to drive it til it died there was nothing else to do....
We did just that (stupid decision, considering recent research. I'm still smh about it) October 2019 it finally died. We have replaced everything we can think to fix.
Y'all. PLEASE HELP US figure out what else we could possible replace to save this truck. We are $8000 into it on top of our note and it kills me to think of giving up now.
Thanks
kbuskill
NE. FL.
Hey Y'all,
We have replaced:
Motor
ECM
ALL Spark plugs
Battery
Remaining symptoms:
Background:
Thanks
Some more info would be great...
Who installed the engine?
Was it new or used?
Did you also replace the positive cable and clean all connections?
Any other information that might be pertinent?
From the codes it sounds like the crank position sensor needs to either be replaced and relearned or at very least relearned.
The other code is just telling you your traction control system is disabled. That should go away after you get the truck running correctly.
Any time there is a misfire the truck will automatically disable the traction control system as well as the stabilitrac system to rule those out as possible culp6for the misfires.
C
Chloe Golmon
Kbuskill
Remanufactured motor from Powertrain, 3 year warranty. My husband and his brother put it in (not their first motor swap). We literally had 2 shops refuse to do the work because of the year model of the truck .
Have not replaced or or cleaned the positive cable. We haven't taken it past idle yet, we don't want to damage anything in the new motor that would kill the warranty.
C
Chloe Golmon
Kbuskill. Also the stabilitrac service light is how it all started in 2018. We got stuck in the sand at the beach. After the rocking and rolling of getting out, the stabilitrack went out somehow and everything else went to hell following that one event.
Kbuskill
Was the engine complete or did you have to swap over the intake manifold and VLOM and throttle body and such?
Do you guys have a Tech-2 or an advanced scan tool? It will pay for itself in just helping you guys figure out quickly and correctly what's wrong. If you guys are in Florida near me I'd be happy to put mine on it.
C
Chloe Golmon
Swathdiver, we're in Texas. Thank you though! We've been using a Bosch scanner, my Brother in Law has a better tool we can grab from him.
The VLOM is new, throttle body and intake manifold are both old. I 've seen some videos where they might need to be cleaned, is that what you're thinking?
Well, they may need cleaning but that usually wouldn't the source of the maladies you're experiencing. I would get hold of that Bosch scan tool and have a look, if its a bi-directional tool that can run tests and relearns and such, you'll quickly identify the problem. My Texas vacation keeps getting cancelled! Have no idea when or if we'll get out there now this year.
C
Chloe Golmon
If it still isn't driving, you're welcome to come by lol. I LOVE my truck, that's why we went down the rabbit hole of trying to fix it instead of unloading it.
I dont understand how 4 different mechanics at this point (including the dealership) haven't been able to diagnose this. Especially considering this happens in a LOT of 3rd gen Tahoe's. Pulling our hair out over here.
C
Chloe Golmon
Notes on the ticket from the dealership:
"Reprogram ecm vehicle started but ran bad clean plugs remove intake and repair ground but vehicle was still missing at number 4 cylinder. Did fuel service - gas in tank could be bad vehicle do need a fuse box it is bad"
Plan to change out the fuse box, and take it to relearn the crankshaft position sensor,clean positive cable.....we'll see what happens
South Carolina
This may be a stupid question, but since it wasn't mentioned I'll ask. Did you try swapping plug wires and coils around to see if the misfire moves? Have you done a compression test? I know it's a new engine, but that doesn't mean it wasn't built on a Friday at quitting time. Just sayin'.
PG01
Up here to the right
The fuse box... it’s in 2 halves take it apart and I guarantee it’s corroded and that was your problem the entire time. They are known for it. Stuck in the sand? As in beach sand with salty water?
C
Chloe Golmon
Yup, we live near Galveston we go on the beach all the time.
Fuse box will here wednesday, I'll keep yall updated, thank you!
C
Chloe Golmon
The scanner we have doesn't tell us which cylinder is misfiring. When we got it ack from the dealership the note said cylinder 4 but our scanner is just showing a random misfire.
We have since replaced the fuse box, the throttle body sensor, and the accelerator pedal. We cleaned the air intake. Used 93 gas. Still a really rough idle. And almost no acceleration. We are going tomorrow to have the crankshaft relearned. Anything else we should have them look for while we have the computer??
thompsoj22
Geeze, Im having an anxiety attack just reading this thread! Proof that without accurate diagnosis money wont fix a computer controlled vehicle. When you were stuck in the sand was there excessive wheel hop? Or just smooth wheelspin? The good in your situation is that it has a consistant miss, Im guessing electrical connector fubar somewhere. Let it idle with the miss and start tweaking every connector that deals with the engine management, including the interior fuse panel, ignition harness under dash,bcm,pcm and every cm you can find. I ask about the wheel hop as that situation will fubar even solid state epoxy encased modules. The injectors/harness/coils were reinstalled on the new motor, you are certain the fuel pump/module and the other components are good?? As stated the tech2 is essential but you have to know how to use it and have values/comparisons to isolate problems. alldatadiy. This vehicle does not have cylinder deactivation correct?
mang213
Bad excuse dude. I just got back from a two week trip down to Texas from Washington DC. Drove my Tahoe instead of flying. Get down there, the weather is great and the fish are biting if you like to go fishing.
@Chloe Golmon As for the misfire and electrical issues for your Tahoe, I had similar issues that I chased around for an entire year on my 2009 Silverado. Quick question. What kind of battery is in that truck? We need to know the brand and type of battery.
Sent from my SM-G960U using Tapatalk
Meccanoble
Georgia
This group just helped me with a misfire. I was going to recommend the same. Swap wires or coils to see if the misfire follows the other cylinder you swapped with.
Towmaster
