Show off your 2015-2020 lowered tahoes and yukons
lynxnova
New Jersey
I got the kit from Tony. The drop is 1.5 in the front and 3 in the back if I recall correctly. Measurements are 34" in the front and 34" in the rear on 26" Staggered offset Intros. The drop is perfect. I would have liked to go lower but 2 lowered trucks is enough. The ride on this one is excellent plus not too low where curbs or the street is scraped when parking or exiting from driveways.
View attachment 247524 View attachment 247525
Hello staggered, what offset are your wheels?
Staggered 02
Hi Alex,
I believe they are a 30 offset but not 100% sure. I would have to check with Intro. I've had them for just about 18 months. Intro knew exactly what offset I needed. I'll see if I can find out for sure. I need to send them a message anyway to get status on a 24" Intro for my 02 that I sent out for repair.
lynxnova
New Jersey
Hi Alex,
Cool[emoji1360] thanks again.
Fsuhammond
Whenever you have a chance I would like to see more pic of you truck as it sits now.
FAA0F611-8924-4751-903B-2D10BD3C1C6B.jpeg 14BFE1F1-7660-45B0-8CFD-54CF30069489.jpeg
Fsuhammond
Truck looks good. I think you're drop sits perfect for your wheel/tire size.
thank you sir. I did add in the 1” spacer only because I’m trying to track down what is causing a vibration at highway speeds. Balanced both 26s and stock wheels, tried djm sway bar links and then added the 1” spacer to minimize driveshaft angle and still shakes. Oh well, it does sit a touch higher in the rear currently compared to those pics but still looks good for now.
lynxnova
New Jersey
Have you tried to see if you need centric hub spacers?
Fsuhammond
I had the hub rings throughout the entire ordeal. I have since sold those wheels and tires and now waiting on a set of 26” snowflakes/honeycombs to come in.
Luie
This thread really makes me wanna buy another Tahoe/Yukon...
Low07Hoe
That looks really good but needs more tire sidewall for me.
It has a good amount because the tire is wide and not stretched on the wheel. Next set I’d like to go up a size and see how they do. My stock 275/45/22 rub pretty bad so I was trying to go avoid that with these.
BADRIDES
What size wheels are those? What kind of backspacing do you have to run? I haven't seen many staggered sets on Tahoes.
Low07Hoe
They are infamous 24 if search for them. They are 24x9 & 24x11 I’m not sure on backspacing they are built for lowered GM truck/suv.
justinakay79
