Show off your 2015-2020 lowered tahoes and yukons
lynxnova
New Jersey
I got the kit from Tony. The drop is 1.5 in the front and 3 in the back if I recall correctly. Measurements are 34" in the front and 34" in the rear on 26" Staggered offset Intros. The drop is perfect. I would have liked to go lower but 2 lowered trucks is enough. The ride on this one is excellent plus not too low where curbs or the street is scraped when parking or exiting from driveways.
View attachment 247524 View attachment 247525
Hello staggered, what offset are your wheels?
Staggered 02
Hi Alex,
I believe they are a 30 offset but not 100% sure. I would have to check with Intro. I've had them for just about 18 months. Intro knew exactly what offset I needed. I'll see if I can find out for sure. I need to send them a message anyway to get status on a 24" Intro for my 02 that I sent out for repair.
lynxnova
New Jersey
Hi Alex,
Cool[emoji1360] thanks again.
Fsuhammond
Truck looks good. I think you're drop sits perfect for your wheel/tire size.
thank you sir. I did add in the 1” spacer only because I’m trying to track down what is causing a vibration at highway speeds. Balanced both 26s and stock wheels, tried djm sway bar links and then added the 1” spacer to minimize driveshaft angle and still shakes. Oh well, it does sit a touch higher in the rear currently compared to those pics but still looks good for now.
lynxnova
New Jersey
Have you tried to see if you need centric hub spacers?
Laurents10
