Show off your 2015-2020 lowered tahoes and yukons
crazycrew
Vacherie, LA
I second this. I had a similar issue as you did when I first installed my lowering kit and adjusted my rear sensor rods and it ended up leveling out all 4 corners. It’s hard to get it perfect with these GM Trucks but mine is within <1/8” from passenger to driver side and I’m happy with it. It doesn’t take much adjustment either; For every 1/8" change in sensor rod length you’ll change the ride height by 3/4".
Exactly as stated. My rods are set @ 2 11/16"
gat0r
DFW
^^^ What calipers do you have? To date, I've had 3 sets stripped, re-coated, lettering, and clear coated. Much easier to clean and maintain. Plus they keep that fresh look and no more fading. Win / win.
StopTech Trophy Sport Big Brake Kit. (15" w/ 6 piston on all 4 corners)
'Callaway' is engraved in them.
Staggered 02
Hmm I see. Those should look great. The new set of Wilwoods that I put on my CC started to stain and fade within a few months. It was then that I decided to get another set and have them refinished. Did one set in red with black lettering and another in charcoal with black letters.
Chevy*808*
lynxnova
New Jersey
2/4 belltech, 26” Denali reps
Only getting 1/2.5 out the setup
Sweet ride man! When you said only getting 1/2.5 out the setup what exactly do you mean? I have an 17 Escalade and I just installed the 2/3-4 drop kit by NorCal and I’m only getting 1” drop in the front. The rear I got the 4” . I’ve used this set up before and I’ve gotten the 2” in front. I spoke with NorCal and he said that the Escalades have 3 different spring rates which will affect the drop in front somewhat.
Fsuhammond
It has settled to closer to 1.75” in the front and after shortening the sensor rod to 2.61” the rear is closer to 3.5 now.
Staggered 02
Hey what’s up staggered, I can’t get enough seeing your caddy! [emoji91][emoji91] what drop did you do and what are your measurements ground to fender lip?
I got the kit from Tony. The drop is 1.5 in the front and 3 in the back if I recall correctly. Measurements are 34" in the front and 34" in the rear on 26" Staggered offset Intros. The drop is perfect. I would have liked to go lower but 2 lowered trucks is enough. The ride on this one is excellent plus not too low where curbs or the street is scraped when parking or exiting from driveways.
lynxnova
New Jersey
View attachment 247524 View attachment 247525
Thanks again, you definately hit this one out the park[emoji1319]. One more question, do you know the difference between the touring mode vs sport mode? All I can notice is the steering feeling tighter but don’t know if it lowers the truck alil more or not
Staggered 02
Hi Alex, thanks for the approval. I don't think that it does but to be fair and clear, I am not the expert so can't say for sure. I do know that I could have gone lower but this works best for me, my needs and the application as sometimes the Escalade gets used to make the Costco runs or various loads.
TexasTaz
