Oh shit my bad, I’m getting old for sure.Engine was off, just turned the key to get everything on
Rpm is at zero. That's definitely a problem if my engine is on
No need to say my bad, I'd be PISSED if I have a check engine light!Oh shit my bad, I’m getting old for sure.![]()
Yeah I just pulled half my truck apart to fix a seat belt light, I know how you feel.No need to say my bad, I'd be PISSED if I have a check engine light!
Well, your just a madman and I definitely don't envy youYeah I just pulled half my truck apart to fix a seat belt light, I know how you feel.
I had to look for a while and at first I thought the same as you. Then I saw zero rpm.Oh shit my bad, I’m getting old for sure.![]()
Me too. LolOh shit my bad, I’m getting old for sure.![]()
Blackbeard tuned. ....that's the sorcery.
Cai, long tubes, no cats, borla exhaust, and a mpg tune from Blackbear. 87 octane 22" wheels as well.
No visual in Pa. It passes emissions somehow. When I had them taken off, my mechanic at the time had no idea how they passed.Curious how you pass the strict ****** emissions tests here with that setup. Pleas tell.
X2. TruthTo be 60 and doing the shit you do, I don't think so.
And honestly, the amount of drone that not having cats creates, it's almost not worth it. I've gotten used to it, but I feel bad for the kids in the back.
But then again maybe not. I noticed areas that appear to have been ground down by a machine on two of the four tires. In those areas the tread depth is less than the rest of the tire by one or two thirty-seconds. I suspect this is a problem and I am not sure this is acceptable. I have attached some photos showing this “grinding” as well as a comparison photo with a tire that does not have this grinding. I bought these from Tire Rack so I have sent an email. Best to get it right.
Wrong they got sued because they lied about ignition issues at one point it was handed back to government motors for a while because of it.. a lot of people got killed because of the engine shutting off at 60-80mphI’m pretty sure this was due to cost savings because a push button is much cheaper than a ignition key cylinder and all that goes into it.
I Doubt this was justification to change vehicles to push-start, it's been around before they were sued and my 2018 has a regular keyed ignition along with tons of other onesWrong they got sued because they lied about ignition issues at one point it was handed back to government motors for a while because of it.. a lot of people got killed because of the engine shutting off at 60-80mph
when they went over a "bump"
https://en.wikipedia.org/wiki/General_Motors_ignition_switch_recalls
124 deaths and many many crashes
All you have to do is delete the downstream O2 sensors in the tune, so the ecm doesn’t look for them. The test can’t determine that, it can only tell if the sensors are throwing a code. Then if there’s no visual inspection, nobody knows there’s no cats.No visual in Pa. It passes emissions somehow. When I had them taken off, my mechanic at the time had no idea how they passed.
I can try and find the tests from the mechanic I take it to. It has passed for the last 3-4 years now since it's been done. It might be longer tbh.
My current mechanic is the number 1 rated mechanic in Lancaster for several years in a row. He will not touch any aftermarket parts other than stuff that is reputable like moog or arnott, dorman, etc. He likes oem and trys to use that the most unless it is a cost issue for the customer.
I can give you their info if you want
That’s weird, and those are brand new tires, right?But then again maybe not. I noticed areas that appear to have been ground down by a machine on two of the four tires. In those areas the tread depth is less than the rest of the tire by one or two thirty-seconds. I suspect this is a problem and I am not sure this is acceptable. I have attached some photos showing this “grinding” as well as a comparison photo with a tire that does not have this grinding. I bought these from Tire Rack so I have sent an email. Best to get it right.
View attachment 249190 View attachment 249193 View attachment 249194
that is the reason for the quicker phase outI Doubt this was justification to change vehicles to push-start, it's been around before they were sued and my 2018 has a regular keyed ignition along with tons of other ones
