kbuskill
NE. FL.
Yes traction control light, flashing engine light. Could there be air trapped in the fuel rails? Possible to put the wrong plug on an injector? Everything looks legit, no leaks, good oil pressure.
I would go back and double check everything you touched, including your Peter if you took a leak while working on the truck... just to rule out anything.
Make sure your air intake tube is fully seated and sealed properly.
Did you remember to plug in the main harness for the coil packs?
PG01
Up here to the right
i wasn’t there :shrug:
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
What did you torque the manifold to out of curiosity.
What this guy said @26:40. Now I am getting a random marble sound out of the driver's side.
89Suburban
SE PA
Is anybody here familiar with doing this valley cover gasket job with the AFM solenoids under it?
IS IT POSSIBLE, replacing just the perimeter gasket and NOT the gaskets for the solenoid oil ports underneath has this thing ****** up and misfiring?
BG1988
cleaned the A/C condenser and add transmission fluid ¾ of Qt not losing any but it was not filled up correctly by who ever did the service before
looks like they were skimming off the top :(
wjburken
Eastern Iowa
Yes.
Your VLOM gasket should look like this I believe. It has the gaskets for your oil ports that pressurize your lifters.
89Suburban
SE PA
Yes.
I concur. I am going with this theory and will start all over again. Just to eliminate that out of the question because I really believe everything thing else is good. That’s the only doubt I have right now is not replacing those. Also found this @ 2:47, cause #2.
Just screwed now until Tuesday to try and track down new parts. Means I have to call out of work too now. And hopefully get this fixed. :(
wjburken
Eastern Iowa
I feel for you my friend. Good luck.
St. Louis
I guess mine does have that foam under the intake. It's further back than I thought it would be and couldn't see it until I got my phone down by the pulley and took a pic
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
BG1988
just rent a car they are renting for practically for nothing now days
Sam Harris
Can’t like
TejasPitt
