Derick
Indy Suburbs
I got new tires recently and I acknowledged that the spare is likely old and cracked. So I took it to the tire shop and they couldn't get the hoist to lower. Did some research, and the safety latch wouldnt release. So I went medieval on its ass today. New hoist gets here tomorrow from Amazon and I'll drop the tire in the am for new rubber. She didn't come quietly, but she eventually came.
All too common of a problem. Glad you got it down.
St. Louis
If the safety latch doesn't release there is a procedure outlined in the owners manual that uses the jack to release it.
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
I had the same problem. I slipped a long extension with a 13 mm socket, through the rim of the spare into the single bolt that holds the entire hoist to the underbody of the truck. I just unbolted the whole assembly, with tire. Careful your arm doesn't get caught between the rim and the ground. Once it was all down I just jammed a screwdriver in the safety latch and pried it open. Beats cutting the cable. Then just lube the hell out of everything.
2001 Yukon SLT
I tried that--didn't work.
Derick
Indy Suburbs
2001 Yukon SLT
But then I wouldnt have gotten the opportunity to get out the air chisel and grinder and go primal on it.. What fun is that?!
Amazes me that, with the same design for decades and after all these years with the failure rate of these things, that some shmuck at GM didnt come up with a kevlar/nylon/abs latching system.....shit, a kevlar vest can stop a bullet ...
I was thinking the same thing they could have used graphite or aluminum or anything that doesn't rust or even just coated it in plastic or something
That would be too easy. That was actually my 2nd hoist. My gf got a flat--without me of course--and someone was helping her, couldn't get it down, so they had to cut it. Wasn't cutting this one!
Geoffsfas10
St. Louis
I lower mine once a year and lube it up/spray it down
Thats actually a really good idea. I had to drop mine on my sierra because the rear brake line exploded...which was fun. And it was stuck on my first attempt. Glad i ended up doing it because a few weeks later I picked up a 1/2"x6" bolt in a tire and needed that spare. and it was 2* outside on January 3rd. That was a fun tire change. ( was better thanks to the good Samaritan who had a floor jack and stands in his car and felt bad because he knew how much it sucked to change )
Geoffsfas10
St. Louis
Super random question....
Anyone know what size the bolt stud is on the underhood fuse box for power? I want to add some power off that stud for the fogs + highs mod and my truck doesnt have a nut on that bolt.
Korbin_A
