why ya wearing a sweater? it's not winter time![]()
Actually that was back in February... thats why i said i forgots
and believe me, Saturday was cold as balls here... 38 was the high
I know that's why I was giving you crap, lol we've been having a heat wave was 95 the other day it's settling back into high 70's mid 80's again nowand believe me, Saturday was cold as balls here... 38 was the high
Oh yeah I forgots... had to get a new gas cap ... it no more clicky clicky...and before some stupid chick ***** light came on i amazoned..View attachment 246921
Yes original diff number than yours, obviously and honestly i don’t remember how i came to order that. Im sure i looked at all the gm parts sites because I normally get my part number then plug it into amazon... like we all do...Hey Pete, was that your original that you replaced? Mine from 2017 says, "Tighten 3 Clicks". I'm looking at some for sale now that don't say anything and others are like mine. The last one purchased from Amazon last year was bad, caused the code to set twice as fast so it was sent back. Don't recall what that one might have said but do remember it was GT295. The former was purchased at a dealership.
20915990 - GT295
Yes original diff number than yours, obviously and honestly i don’t remember how i came to order that. Im sure i looked at all the gm parts sites because I normally get my part number then plug it into amazon... like we all do...View attachment 246933
dealer should have it, when my "tighten gas cap" message popped up I just went and bought a new one, wasn't the problem but o'wellThanks Pete, for whatever reason that one is not made for mine.
Dyno tune........... 312rwhp (stock heads and VVT cam)
The numbers are low, but damn its fun to drive.
Yeah but that 1/4 mile time...Ripped off a nice 0-60 last night on my way to the store.......spun through 1 gear though
I think simple green is a great one for cleaning them to dress it, Chemical Guys Silk Shine.Had a very slight “hiss” sound under acceleration. A quick visual showed all the exhaust manifold bolts were intact so that was good. Took a chance and checked tightness on them found two loose ones on the left side. The first and second to last ones. Pulled them out, wire wheeled, anti-seize and tightened up. No test drive to confirm. Nice to work under there after washing it down. What does anyone use as a detailing chemical under the hood?
I sprayed it down with Gunk Engine Bright and hosed it off. Looks so much nicer. Got some frame areas to treat with Ospho when it gets warmer. Works best when its hot and muggy. Then paint it chassis black.I think simple green is a great one for cleaning them to dress it, Chemical Guys Silk Shine.
(Now that I said that, I need to do mine!!)
I've used "purple power" as a de-greaser, stuff works and it's strong you def don't want to be inhaling it, that and good o'l soap and water with a pressure washerHad a very slight “hiss” sound under acceleration. A quick visual showed all the exhaust manifold bolts were intact so that was good. Took a chance and checked tightness on them found two loose ones on the left side. The first and second to last ones. Pulled them out, wire wheeled, anti-seize and tightened up. No test drive to confirm. Nice to work under there after washing it down. What does anyone use as a detailing chemical under the hood?
Those are great in theory... but to be honest with you they are nothing but a loose/bad connection waiting to happen... been there done that, tossed it in the trash...well after running the battery(s) on maintenance mode on the charger & charging for a total of almost 3 days the 2nd battery went up to 100% (per the charger anyway)
I think i'm going to use one of these quick connects which gives me a top post terminal and a screw terminal option and run the ground from the 1st & 2nd battery together so they are both connected to the RVC, I'll take out the white plastic part for a better connection and then I just need about a 80" ground cable made up so I can run it across the firewall to the 2nd battery. then see if that makes any difference with charging, I suspect one my battery's is not up to ***** but time will tell.
