Powerstep running boards
avalonandl
Troy, MICH & Naples, FL
I had to pull them off as one was stuck in up, the other down. They are in Michigan and I am in Florida.
My mechannic could not get them working. I need someone to walk me through getting them working.. BTW search function seems broken.
Or i want factory replacements - my blind spot alert is malfunctioning since taking them off.
wjburken
Eastern Iowa
The passenger side one on our 2013 retracts about 50% of the time. Never got it stuck in the retracted position, just in the extended position. I tried some white lithium grease on all the hinge points and that seemed to help at first. About to take them off, or at least loosen the bolts a little and then re-install to see if something is just binding somewhere from possibly getting tweaked sometime before we owned it.
avalonandl
avalonandl
I found a youtube.... will have to wait for me to get back to where they are.
I was hoping for some additional info from someone who has really worked on them.
Matt_
Lithium grease is actually bad for the hinges. It captures debris and increases friction over time.
AMP recommends only using silicone spray lubricant on their hinges.
I had an issue with one of mine binding. I think I rushed the install, so I took my time and made sure I following the alignment procedure carefully and that the step was free to move along it's full range of motion. Been good since.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
I would like to find a graphite based lube that dries slowly so it can ********* into the hinges before it dries. I think this plus my mud flaps will help keep them working.
kbuskill
NE. FL.
Slip plate...
SLIP Plate | Slippery When Dry | Dry Graphite Lubricant
https://www.slipplate.com/
Used to use this on my trailer when I hauled cars to lube all the moving parts. Better than grease because it won't collect dirt/sand and it doesn't get all over you if/when you brush up against it.
George B
¯\_(ツ)_/¯
Slip plate...
Like @Matt_ said.... they all recommend silicone spray.... i spray the balls out of mine every time I think about it.... stupid salt/rusty state I live in. I also spray it on a rag and wipe my door seals/rubber.
https://www.berrymanproducts.com/22-uses-silicone-spray/
Good stuff!
scottd
