2008 Yukon Denali, 135k miles, part 2!!
petethepug
Michael
SoCal
Just had the rack on my 08 replaced under warranty after the service contract had replaced it due to leaks. The rack actually cracked because it was made out of cheap ass pot metal. This was supposed to be a AC delco rebuild too. What gives?
T
tgui
Just add jb weld
Had some more time. Cross member out. Oil draining.
If those transmission oil cooler lines are weaping or leaking, now is the easiest time to replace them!
When you're done, come on over and to our house and do this to mine, I'll watch from the window, you know, social distancing and all! LOL
T
tgui
Did the trans lines almost a year ago.
I'll be over March 34th, sound good?
Is your pan also leaking?
LOL! No, the pan is dry. Just nearing time for the lines to be replaced. Plan is to also replace the motor mounts then too and taking down the diff and center support will give me lots of room!
Would like to replace some noisy bearings inside front axle, and will someday regear to 3.73s if we do 34" tall tire.
petethepug
Michael
SoCal
Couldn't tell is you already installed poly on you're sway bar bushings. Lube those puppies up with poly grease realllly good or they'll squeak when it's cold. You're getting close to a drive train that doesn't leak a drop soon.
T
tgui
No poly, mayhaps I'll order a set.
T
tgui
Got the pan down. Crap all over my face too. Colorful language was used.
Gasket was completely failed. What a mess. How, I have no damn idea.
Remember 170k miles.
Not bad. Crap on the bottom was from when I dropped it.
Some sludge in the back there. I'll take the windage try off later. Its goop, not hard.
Oil pickup screen ok. No crap.
New oil pickup gasket.
I mean, 170k miles, looks ok.
Looks like rear main seal is ok.
New gasket with black rtv for the corners.
Yeah overkill but cheap. New one of these guys and gasket. I'm not playing games!!
Not bad :)
T
tgui
I used a razor and scotch brite. This is my first oil pan gasket replacement.
Is that surface clean enough for the gasket?
How much black rtv, just in the corners?
dizhai
