Transmission fluid change
V-8 Johnny
I just got a '05 tahoe this morning. The truck has little over 200k on it. Shifts like butter. But the fluid is brownish. I want to drop the pan and change the filter but, can't do it because my leg is in a cast. And my ol' lady needs this thing ready for the road asap. Wanted to see what you guys think about me using a hand pump to get the old fluid out and put fresh fluid in.
,Thanks
SnowDrifter
Sasquatch Country
TBH That's the preferred method if you just want to change the fluid. Don't do the trans cooler line stuff you may have seen posted. It's just... Begging for trouble
Stock filters are rock catchers. They don't really get dirty nor benefit from changing. They're just a glorified screen. Real benefit of dropping the pan is to clean the ferrous debris out.
Long straw down the dipstick, suck, fill. Need 3.5qts or so each time you do it
V
V-8 Johnny
Thanks, gonna pick up some dex lll and take care of this in the morning.
Bob2C
Northern VA
Doesn’t the ferrous debris get attached to the magnet anyway? I’d prefer the tube method a few times with a few hundred miles between.
SnowDrifter
Sasquatch Country
Realistically all you need to do is start the car and shift it through the gears a couple times. Torque converter always has fluid going through it, just actuate the valves in the body
Bob2C
Northern VA
What kind of straw are you using to insert into fill tube? And pump?
Bob2C
Northern VA
If anyone needs some. Was 13 bucks yesterday. 17 not bad.
smokey_mountain
I bought a very much the same Pela extractor but a) metal re-enforced tube is a bit short and it did not go into the dipstick to reach the fluid in the pan (I guess there are two tight turns; b) anyone knows if there is a longer but still metal re-enforced thin hose that we can attach to reach the fluid. My transmission is 2018 6-speed.
ladorn45
Do i use this fluid for a 2001 tahoe as well. I know 05 are the same for alot of things but just want to make sure thanks
Bob2C
Northern VA
I’m not too sure. There are others on here that might know
SnowDrifter
Sasquatch Country
Go to a bicycle shop, get some of the stiff brake / shifter cable guides, cut to length, get a rubber stopper or cork that fits your flexi plastic tubing and that, press fit, and there ya go
john1989
