I have a Yukon Denali that started to run hot and found the water pump having a leak dripping down. After looking it over, I could not see an issue with hoses, so assume the pump is out. I have removed it and cannot find a weep hole visible. One of the gaskets appears rather bad and I am wondering what would cause this and if this might be the source of my leak. Thoughts? I am doing as others suggest and replacing the pump, T-stat, AC belt, tensioner, pulley and lower hose. Mileage is about 145k. Does someone have torque specs on these they could share? Only finding them for the 5.3. Thanks.
