Folks:
Driver side wiper hose, of my 2008 Denali XL, snapped right at the connection that goes down into the cowling. So you see hose come from the plastic part on the car but the little nub at the cowling is broken. Called local GMC dealer to find out if there is a replacement part that snaps into the cowling and then into the existing hose. He said, looking at the diagram, you have to buy a $30 hose assembly that runs from the wiper to the pump. What the? So that snap part isn't replaceable? Only the entire hose assembly? Sounds like a lot more work than is necessary.
Anyone had this small part break and found a reasonable fix? I'm not as worried about the the $30 as I am the labor to pull the hose from the windshield wiper pump all the way to both wipers. Doesn't sound like fun. While not an all-day job, probably means removing batter, battery cage, wiper fluid tank and a bunch of clips.
Am I wrong?
TKH
Am I wrong?
TKH
