Dantheman1540
It very much is! My Yukon has factory hydroboost and I love it
Do you know what factory option had to be chosen for an SUV to get hydroboost? Mine is very base model so I thought it was weird that it had it.
Maybe it was added by a previous owner.Do you know what factory option had to be chosen for an SUV to get hydroboost? Mine is very base model so I thought it was weird that it had it.
Sucks when your shop is full. Good oil can't wait till it warms up in a few months so I can start running the thicker oil.It was time for a little maintenance tonight and since my shop is currently full I had to do it in one of my barns.
Changed oil over to some thick stuff since the rear main leaks a bit. Drain plug looked normal and I cut open the filter which looked clean as a whistle. I think it's been 5 or 6k since the last oil change and around 8 or 9k since I did the filter when I first bought it.
Also added some tow hooks I picked up used.
View attachment 240578 View attachment 240579 View attachment 240580 View attachment 240581 View attachment 240583
ton) I don't think it will hurt it a bit.I use to run that exact oil in my bike when it first became available.(2013)I was surprised how much quieter the engine sounds with the thicker oil. Oil pressure went up considerably which is to be expected but since this motor has unknown miles (Probably a metricton) I don't think it will hurt it a bit.
Also its kinda fun to slum it under a barn like good ole times.
Which did you use?I was surprised how much quieter the engine sounds with the thicker oil. Oil pressure went up considerably which is to be expected but since this motor has unknown miles (Probably a metricton) I don't think it will hurt it a bit.
He's got a picture of it.Which did you use?
Must be rough having to decide which barn will work best for your Oil change.
Which did you use?
I have no clue if it was added by a previous owner. This thing was supposedly owned by an older couple since new so I have no clueMaybe it was added by a previous owner.
Check your rpo's?I have no clue if it was added by a previous owner. This thing was supposedly owned by an older couple since new so I have no clue
I like the tall Napa Pro Select 21522.Is that the tall Wix filter 51522XP for the 5.3?
Check out the many YouTube video where they cut open filters and compare them.I just recently got a oil filter cutter so I'm excited to see what different filters look like inside after so many miles.
Check your rpo's?
