R3cord303
Posse In Effect
Oregon Valley
maybe jack it up and take the wheels off, then start it up and turn it back and forth to see if you still get the noise, get a helper and maybe you can narrow it down.
i’ll jack it up tomorrow night and do the 12-6 and 9-3 o’clock shake test. Im gonna take Friday off and have the tire shop look at it. They did the front end on it 8 or so months ago
Here’s a video of the noise. It makes the same pitch of sound going over bumps in parking lots as it does when turning the wheel- but only sometimes.
I didn't notice anything out of the ordinary even after watching it twice. I must have the same problem then! How many miles and have you done the ball joints yet?
mtc1328
Indianapolis, IN
I received the brake sensor I ordered in response to my intermittent cruise control, similar issue to what @mattjones posted. @Doubeleive then posted about how the switch allows a little movement, so I tried a little kick-tap near the top of the brake pedal arm to re-seat the switch. Sure enough, the little kicks make the cruise control work again. I imagine I will end up installing the new switch later though, since it was cheap enough, and kicking things to make them work isn't a good long-term solution.
Thanks again for everyone's contributions on this forum.
992dr
Eastern N.C.
I'm with Swath, I don't hear anything out of the ordinary but, I do hear a nice sounding exhaust :)
I haven't done jack but, I did get my new rear light harness, drivers door hinge detent kit and rear glass lift cylinders
R3cord303
Posse In Effect
Oregon Valley
237,000 and yeah the whole front end was replaced save for the steering rack 15,000 ago.
Thank you. Its the stock muffler and tube diameter just removed the worn out cats and the resonator. I know somethings off. Buddy at work says its the power steering pump but will see. I’m going to have the tire/suspension shop look at it Friday.
what happens is the switch can turn a little, so if it turns it then looses contact, if you kicked it then it might have just turned it back to where it should be, if you look under there and grab it you will see the switch doesn't stay very tight it can turn up/down by hand. stupid design it should have a notch to keep it where it should be.
992dr
Eastern N.C.
Gotcha, it sounds good.
Hmm, mine makes a similar sound and a clunk haha, that's the ISS though. Need to fix or replace that. That whine though, could it be low on fluid?
Now that I think about it, I need to go check my fluids.
You can see there's a minor leak or weaping on the inner tie rod boot, that's the only thing that caught my eye but since it wasn't wet, might check it for play.
R3cord303
Posse In Effect
Oregon Valley
I noticed that too. It does weap a little bit. Thankfully its a leak free vehicle.
I will check for sure tonight.
And thank you! Im pretty happy with the sound. I will at some point doing a whole new exhaust though. I wanna do a side exit
mattjones
VA
Yep, I had this issue on my last Tahoe probably like 5 or 6 years ago and messing with it would solve the problem temporarily but eventually the cruise control would go out again. Since it's a $10, ten minute fix I didn't even bother messing around with the one that was in there already and just ordered a new one.
Bigkevschopshop
Northside H-Town
Commute best. 35 miles of freeway on the way home just now.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Lol, I was just looking at that--but dreading it!
If we got 3 full months each of the fall and spring “in between”weather like we used to I wouldn’t complain. Seems like it goes right from one extreme to the other anymore. Remember beautiful skies 55/75 temps for more than a couple weeks? Miss that shit.
Sam Harris
No shit! It’s that global warming you know.. ask Algore!
I remember those days--many moons ago.
Korbin_A
