2004 6.0 NV4500 Tahoe
Dantheman1540
Sugar Loaf Mountain
Alright, I figured I should make a little thread on here since there seems to be a lot of activity on this forum. This build isn't all about performance it's a little bit of everything.
Went and bought a 2004 2wd 6.0 NV4500 5 speed manual transmission Tahoe out in the great state of Texas in Aug 2019. The owner was a respectable member of another forum and when he posted it for sale I jumped on it right away. My other truck has an NV4500 which I have had for several years and in and out multiple times so I already knew I really liked the NV4500 and getting a Tahoe already swapped saved me a lot of work
EDIT: Turns out the previous owner was a member here as well https://www.tahoeyukonforum.com/threads/04-tahoe-6-0-nv4500-2wd.113658/
Mileage
233,*** - 8/20/2019 When Purchased
239,324 - 2/14/2020
260,000 - 1/6/2021
277,640 - 1/11/2022
280,525 - 5/14/2022
296,550 - 7/13/2025
297,344 - 6/4/2026
Front suspension/Brakes:
-Atomic fab & perf Coilover swap/torsion bar delete
-Viking double adjustable shocks with 1,000lb springs
-Kryptonite Tierods (warranty replaced driver inner at 297,344)
-Hellwig 7702 sway bar
-OEM replacement idler arm, idler bracket, and pitman arm
-Both Front Wheel Bearings #(Timkin SP500300)
-Poly Front end link bushings (replaced 297,344)
-KYB Steering stabilizer (Replaced 297,344)
-2021 Tahoe 4 piston brake swap
Rear suspension/axle:
-2011 AXN 9.5 Semi Floater 14 bolt axle (Out of 2wd 6.2 Yukon Denali with 132k) Swapped in Spring 2020.
-3.42 gears
-1410 forged yoke
-G80 OEM locker
-Eibach 3' drop springs
-Viking Warrior series shocks with shock extenders
-Airlift rear bags
-Free travel mod
-Hellwig rear sway bar and end links
-PML slim diff cover
-Spohn rear LCAs
-QA1 Panhard
Engine:
-Refreshed LQ4
-Cam is a TSP 224/228 113lsa .600/.600 lift
-Wilkes ported 243 heads with Stainless 2" valves
-CHE rocker arm trunion upgrade
-Dual comp cam valve springs
-AEM Wideband AFR and tuned VIA HP Tuners by me
-Arp Head bolts
-Katech C5-R timing chain
-LS2 90mm with 00-02 throttle box and 6-8pin adapter NO XLINK NO REP!!
-NNBS Intake
-AFE Cold air intake
-Long Tube headers
-Lots of mufflers but also an electric cutout
Transmission:
-Rebuilt GM NV4500
-Hurst Short Throw Shifter (handle length part#:0295)
-Clutch master rod extension (Custom made by me)
-LUK OEM replacement clutch
Exterior mods:
-Paint correction
-Morimoto HID retrofit headlights
-Paint matched handles
-HD front end swap
-Rare style rear hatch glass
-Trailer connector relocated to bumper
-Esky roof rack
-Esky rear appliques
-Diode Dynamics SS3 Pro amber fog lights
-Z71 Valence (Black)
-275/60/20 2022 GMC Wheels
Other random things:
-Full fluid change
-Full interior de-funkify
-Knock sensors replaced as well as Valve covers because one was cracked and leaking.
-Weathertech mats everywhere
-Kenwood8906x Head unit
-JL Audio C3 door speakers
-Custom sub enclosure with JL12"W3
-JL RD900/5 powering the system
-Back up and dash camera
-Full sound deadening on doors, floors, and rear hatch
-5% tint all around
-4hi mod
Probably more I'm forgetting.
The next parts will be:
-Pull one decent-sized dent
-BOOST!
The overall goal is to have a good daily driver that I can hook up a car hauler and tow my "Race truck" or any other reasonable load of crap and also have a little fun toying with other trucks and SUVs from light to light.
Here's a crappy little video walk around from when I first got it.
And some pics
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
It was time for a little maintenance tonight and since my shop is currently full I had to do it in one of my barns.
Changed oil over to some thick stuff since the rear main leaks a bit. Drain plug looked normal and I cut open the filter which looked clean as a whistle. I think it's been 5 or 6k since the last oil change and around 8 or 9k since I did the filter when I first bought it.
Also added some tow hooks I picked up used.
20200214_194618.jpg 20200214_194443.jpg 20200214_203040.jpg 20200214_195516.jpg 20200214_193931.jpg
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
How many mpgs do you get on the freeway? Since it's a 5spd, I would think you get more than automatics.
The one long trip I did I got mid 18s 2 of the three tanks and a low 19 on the other. That was going 75-80mph. With lighter wheels I think it would do better. Also that trip it had some unbalanced Bridgestone tires that rode terrible going faster helped smooth it out.
Just filled up today had gone 198 miles and put 11.4 gallons in it which is 17.3mpg that was mostly city driving. Best I've gotten in awhile and I always hand calculate cause I'm weird.
I remember when this was posted for sale. Glad to see it's back on the forum! Your MPGs are pretty much inline, if not slightly better, than what the 4L60 should've gotten. The extra rolling resistance of them 285s accounts for a little loss.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Yeah next set of tires if I keep the LTZ20s I will stick with 265s in the front as the 285s rub ever so slightly at full lock. I could also work on getting lean cruise dialed in on the tune to squeeze another mpg or 2 out of it. But I'm not to bothered by it. My other truck gets 10mpg downhill in neutral with a tail wind so 15s is nice lol.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Wix filters=Good. I use the AC Delco on mine but would never hesitate with a Wix filter. I used them on my Harley's too.
I found a 12 pack of the longer Wix filters super cheap on Amazon one day so I ordered 24 of them lol.
Also Axekick the previous owner was a super standup honest guy. I asked him a ton of questions about it, flew into Austin TX he picked me up in it made the deal and off I went. I think hes building jeeps now.
GMT800 2005 Tahoe Z71
Navy Supporting Member
Lots of Jeep builds here in Oregon with the off road crowd. Have helped on some but they don't drink beer as fast as I do, so I get bored easily. They talk about the Dana 44 axles too much. Their eyes cloud over when I talk about a Dana 60 and a GM 14 bolt full float. Go big or go home.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Jeeps don't do burnouts so I have no interest. I used to do more offroading when I lived up north but since Florida is either sand or mud I keep out of the mud and only go sand blasting occasionally.
I really don't remember the part number but I can look. It will fit all 4.8, 5.3 and 6.0s. I like that it its longer so theres more to grab onto when removing.
I am an Amazon member so if I can get a case price for mine I am gonna do it. Thanks.
When I lived in Missouri we had Mud Runs all the time. Always took my wife with me in the passenger seat. She loved it more than I did.
There is a thread here about the swap from vacuum boost to hydro-boost on the GMT800. It is recent too. Was that you or another member. At 67 I need reminding sometimes.
Thanks for the filter number. I thought that was it but wanted to be sure.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
No it wasn't me this one had it when I bought it but I did it to my silverado. Seriously massive improvement! The tahoes pedal seems real squishy though so I think it needs a good bleed. Stops fine when you finally get the pressure applied but I'm pretty certain theres either air in the lines or the rubber hoses and flexing bad.
How old is the fluid? Power steering builds a lot of heat and that fluid can break down before you know it. Plus it is doing 2 systems now instead of just the one. How old are the pads? Good quality ceramic pads? It would be a very rare thing for air to be in there after even just 2-3 days of normal driving. That air gets cycled to the top of reservoir pretty quickly. If it is running hot and starts to aerate then that could be a source as well. P/S cooler in good condition?
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
So the powersteering fluid still stays separate to the PS system even with hydroboost. It just sends the booster pressure and then it routes back to the PS reservoir. The brake fluid could be ancient I'm not sure. It looks very dark and probably needs replacement.
I guess when I said I changed all fluids in my original post I didn't mean for that to include brake or clutch fluids. As those are more than a 1 person job.
jkhuntzinger
