Lq4 rering
Mechanic421
06 Denali XL
Statesville North Carolina
So slow right know so I thought time to rering my spare lq4. My engine in my truck now runs great just has 205000 and starting to leak pretty good. This engine has 175000 it ran well also when pulled but also leaked. So I disassembled it today and was very pleased! Mains look like new rods have some but very little wear but oil rings are frozen. This will be a very budget build. Thinking Vincie Torque cam ,single coil springs, under cut stainless valves, rering kit ,polish crank,stock chain,moly push rods , trunnions ,good lifters and some stuff that I forgot to mention like all the dam bolts I have to buy.
3B1D9342-4F78-40B0-A02B-A1F37FCE36B1.jpeg 8D2C4E67-5838-4929-938E-D2F10D6B1D6B.jpeg 44C3E092-F0A0-4D26-9D7F-DFF8848E7BC9.jpeg CE900511-F81A-4267-81F8-C26E24D53CA1.jpeg image.jpg
Mechanic421
Mechanic421
06 Denali XL
Did not have time for assembly pics but just waiting for pushrods,trunnions,knock sensor and knock sensor harness. So everything is standard lq9 pistons ,ring gap spec out good. **** rods ,polished the crank and balanced. Vinci 554 cam,Vinci double valve spring kit and Vinci lifters .hexajust chain to degree cam .I ported a 235 mellings oil pump.Heads looked good so I lapped the valves and installed the seals Vinci sent in spring kit.Always replace mr barbell! I will update when we get it installed.
8C633989-DEDD-4F4C-956C-090250B1556F.jpeg 7475E8A2-1351-46EC-A23D-367A6733BEBB.jpeg
Mechanic421
Mechanic421
06 Denali XL
GRRRR so #8 exhaust lifter stuck won’t compress! Holding valve open checked like 3 times,it is in the cup. Binding the spring have call and email out to Vinci still waiting. I have pressure on it hopefully it will collapse.
Dantheman1540
Sugar Loaf Mountain
That's really good customer service.
Did You mill the 317s at all?
Also since it got a little more serious do you have a power goal in mind?
Mechanic421
Mechanic421
06 Denali XL
No milling , changed to lq9 piston and stock rods are 6.098 and new rods are 6.100 over 10:1 probably close to 10.5:1. No real goals but thinking with with cam,8.1 injectors ,1 3/4 primaries bbk drop in headers and black bear tune thinking maybe 400ish. More of a towing engine really.
Dantheman1540
Sugar Loaf Mountain
It gets mid 15s around town but I don't get much highway time. The one time I did get a long distance trip in it got 18-19 at 75mph. I havent towed anything long distance yet but I would expect between 9-12. I'm kinda impressed with it because most people I know with a 6.0 in anything get 12 flat. My RCSB with a 4.8 never got better than 13, now with a radical 6.0 and blower 10mpg is the average and 6 is the best towing.
varminpoolteam
